You can compute the difference between the base point and the apex. The distance between these points will be the height of the cylinder/cone. In order to align the cylinder with the line between these points, you can
- compute the cross product between the difference and the Z-axis (to obtain a rotation axis)
- compute the angle between the Z-axis and the difference (which is the rotation angle)
From that, you can create a quaterinion, put that into a matrix, and apply that matrix to the cylinder geometry.
Here is a sandcastle with a few examples, with the “entry point” being the function
function createCylinderPrimitive(
position0,
position1,
topRadius,
bottomRadius,
color
that allows creating arbitrarily-aligned cylinder primitives.
(Edited to properly rotate around the base of the cylinders)
