I would like to modify the picking to allow multiple picks to show up. I would like to do this with the “Ctrl” + click modifier.
Here is my attempt at maintaining a “flag.” Unfortunately, this only works for “Command” on Mac and won’t work for “Ctrl” + click because it somehow prevents the default Cesium picking from functioning (i’m guessing Cesium’s picking is bound to LEFT_CLICK and not LEFT_CLICK with the Control modifier.
App.prototype.keydown = function(evt) {
// Window context
if (!evt) evt = event;
if (evt.keyCode === 224 || evt.keyCode === 17 || (evt.keyCode === 91 || evt.keyCode === 93)) {
this.app.cmdEngaged = true;
App.prototype.keyup = function(evt) {
// Window context
if(this.app.cmdEngaged) {
this.app.cmdEngaged = false;
This is the “getFeatureInfo” callback.
if (that.app.currentPicks.length > 0 && !that.app.cmdEngaged) {
that.app.deletePicks();
that.app.currentPicks.push(that.app.viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(json.lon, json.lat),
label : {
show : true,
outlineWidth: 4,
font : ‘14pt Lucida Console’,
style : Cesium.LabelStyle.FILL_AND_OUTLINE,
text : (value.toString().length <= 5 ? value : parseInt(value).toFixed(1))
Showing multiple labels on the map like below.
Trunk/master.
I appreciate any tips or recommendations which might get me on the right track to getting a platform-agnostic approach built. I’m on Mac but the majority of my users are on Windows and by using the “Command” key code, only the “Windows” key works for this. “Ctrl” seems like the best key for both platforms.
