I am trying to cull a custom primitive so that it doesn’t show when I rotate the globe. I know this has something to do with setting the bounding volume in the draw command, but I haven’t been able to get it to work.
Here is sandcastle example. It shows 2000 lines that are still visible when I rotate the globe.
I need to make thousands of moving lines for a project to visualize wave data. I can’t just use polylines because it would be too slow and I need to animate them.
Cesium 1.50.0, Windows 10, Chrome
Thanks for you help
