A path is drawn across the globe using a polyline. However, the polyline sometimes disappears depending on zoom / rotation.
I’m guessing this has something to do with culling objects past the horizon or similar filter.
Try zooming into Australia:
In this simplified test if you zoom into either end of the polyline then tilt then rotate the line will also dissaper as it rotate along the bottom of the screen.
http://www.globaltimoto.com/cesium/Apps/test.html
Polylines describing a path to travel should always render. Is there a way to achieve this ?
This is present in v1.48 and v1.49
