In some camera angles, we see polylines clip as if they’re passing through terrain. However, the lines that are clipping aren’t low enough to be clipped by the terrain, so we’re not sure what’s causing the visual issue. The clipping changes as you move the camera.
View the graphic from a bird’s eye view:
The above is what we expect to see for all camera angles: The lines are clipped only when they enter terrain ,and otherwise (like on the right side of the ellipse) are not clipped.
Next, zoom in a little and tilt the camera slightly downwards
Now we can see the lines that were previously unclipped on the right side are now being clipped by something. These lines are well above the terrain in that area (rotate the camera to a horizontal perspective to verify), but appear to be clipped regardless.
This “clipping” seems to change as you rotate the camera around the graphic. We’re looking for a way to avoid this clipping. Is this a known issue?
This issue only occurs when terrain is used. The lines have to be somewhat close to the terrain for this issue to occur, and it doesn’t seem to occur in Cesium 1.43.
We have some graphics in our application that show many lines clustered together like the above images. We’re currently using Cesium 1.43 and it looks fine, but when upgrading to Cesium 1.59, we see the above clipping behavior arise.
The issue can be seen in Cesium 1.50 through 1.59 on windows in chrome as far as I know. When we use Cesium 1.43 we do not experience the issue
