in the standard sandcastle for Polylines
the “Blue dashed line” is flickering if I move to the left or right. You can see this, because the line end/start changes. If I zoom in/out I think the flickering isn’t so strong but still there - my customer doesn’t like this behaaviour, any ideas/tips to change.
Regards
Rüdiger
Hi @Ruediger_Brand,
Thanks for reaching out with your question! I also appreciate that you took the time to send over a sandcastle demo.
I took some time to play around with the sandcastle demo that you shared. I am not sure if I was able to fully reproduce the visual artifacts that you noticed.
If possible, could you share a screenshot of what you are seeing? In addition, providing information on your system (operating system, browser, etc.) would be very helpful.
-Sam
Hi Sam,
you see the flickr if you move with the mouse - the line endings are changed, there is a “running effect” at the line:
In the screenshot you see that in the dashed polyline the line endings chang if you move the map
In cases where we have a different pattern the “running effect” is very disturbing.
Regards
Rüdiger
Hi @Ruediger_Brand,
I appreciate the screenshots. They definitely help clarify the issue that you are seeing.
I don’t know of a quick fix to this using our API. I recommend opening an issue on our GitHub page that outlines this problem for our CesiumJS squad to take a look at. Be sure to check if there are any other GitHub issues for similar problems and feel free to reference this thread when creating your ticket.
Sam
