As my Cesium application will have a custom data source, I was looking at the Custom Data Source example. I noticed that the Sandcastle example redefined all the fields that are in Cesium.DataSource - are these all required if you’re creating a custom DataSource, or are some optional?
I noticed that DataSource is not supposed to be instantiated directly, though there is also a CustomDataSource object that does seem intended for this purpose - is there a reason I would want to reimplement everything in my own Object rather than just base things on CustomDataSource (and adding functions that are necessary)?
Tim
