Hi
I have read the Geometry and Appearances Part 2 (https://github.com/AnalyticalGraphicsInc/cesium/wiki/Geometry-and-Appearances), and try the code, the Tetrahedron shape is ok, the normals is ok, but the shading has no effect.
how to make the shading worked? Thanks for the help.
here is the code, you can run it in Sandcastle.
var TetrahedronGeometry = function() {
var negativeRootTwoOverThree = -Math.sqrt(2.0) / 3.0;
var negativeOneThird = -1.0 / 3.0;
var rootSixOverThree = Math.sqrt(6.0) / 3.0;
var positions = new Float64Array(4 * 3 * 3);
// back triangle
positions[0] = 0.0;
positions[1] = 0.0;
positions[2] = 1.0;
positions[3] = 0.0;
positions[4] = (2.0 * Math.sqrt(2.0)) / 3.0;
positions[5] = negativeOneThird;
positions[6] = -rootSixOverThree;
positions[7] = negativeRootTwoOverThree;
positions[8] = negativeOneThird;
// left triangle
positions[9] = 0.0;
positions[10] = 0.0;
positions[11] = 1.0;
positions[12] = -rootSixOverThree;
positions[13] = negativeRootTwoOverThree;
positions[14] = negativeOneThird;
positions[15] = rootSixOverThree;
positions[16] = negativeRootTwoOverThree;
positions[17] = negativeOneThird;
// right triangle
positions[18] = 0.0;
positions[19] = 0.0;
positions[20] = 1.0;
positions[21] = rootSixOverThree;
positions[22] = negativeRootTwoOverThree;
positions[23] = negativeOneThird;
positions[24] = 0.0;
positions[25] = (2.0 * Math.sqrt(2.0)) / 3.0;
positions[26] = negativeOneThird;
// bottom triangle
positions[27] = -rootSixOverThree;
positions[28] = negativeRootTwoOverThree;
positions[29] = negativeOneThird;
positions[30] = 0.0;
positions[31] = (2.0 * Math.sqrt(2.0)) / 3.0;
positions[32] = negativeOneThird;
positions[33] = rootSixOverThree;
positions[34] = negativeRootTwoOverThree;
positions[35] = negativeOneThird;
var indices = new Uint16Array(4 * 3);
// back triangle
indices[0] = 0;
indices[1] = 1;
indices[2] = 2;
// left triangle
indices[3] = 3;
indices[4] = 4;
indices[5] = 5;
// right triangle
indices[6] = 6;
indices[7] = 7;
indices[8] = 8;
// bottom triangle
indices[9] = 9;
indices[10] = 10;
indices[11] = 11;
var attributes = new Cesium.GeometryAttributes({
position: new Cesium.GeometryAttribute({
componentDatatype: Cesium.ComponentDatatype.DOUBLE,
componentsPerAttribute: 3,
values: positions
var boundingSphere = new Cesium.BoundingSphere(new Cesium.Cartesian3(0.0, 0.0, 0.0), 1.0);
var geometry = Cesium.GeometryPipeline.computeNormal(new Cesium.Geometry({
attributes: attributes,
indices: indices,
primitiveType: Cesium.PrimitiveType.TRIANGLES,
boundingSphere: boundingSphere
this.attributes = geometry.attributes;
this.indices = geometry.indices;
this.primitiveType = geometry.primitiveType;
this.boundingSphere = geometry.boundingSphere;
var scene = viewer.scene;
var ellipsoid = scene.globe.ellipsoid;
var modelMatrix = Cesium.Matrix4.multiplyByUniformScale(
Cesium.Matrix4.multiplyByTranslation(
Cesium.Transforms.eastNorthUpToFixedFrame(ellipsoid.cartographicToCartesian(
Cesium.Cartographic.fromDegrees(-100.0, 40.0))),
new Cesium.Cartesian3(0.0, 0.0, 200000.0), new Cesium.Matrix4()),
500000.0, new Cesium.Matrix4());
var tetrahedron = new TetrahedronGeometry();
var instance = new Cesium.GeometryInstance({
geometry: tetrahedron,
modelMatrix: modelMatrix,
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.WHITE)
scene.primitives.add(new Cesium.Primitive({
geometryInstances: instance,
asynchronous: false,
appearance: new Cesium.PerInstanceColorAppearance({
flat: true,
translucent: false
scene.primitives.add(Cesium.createTangentSpaceDebugPrimitive({
length: 0.2
