the code run success in version b29 is below:
var TetrahedronGeometry = function(){
var negativeRootTwoOverThree = -Math.sqrt(2.0) / 3.0;
var negativeOneThird = -1.0 / 3.0;
var rootSixOverThree = Math.sqrt(6.0) / 3.0;
//四面体的四个顶点
var positions = new Float64Array(4 * 3);
// position 0
positions[0] = 0.0;
positions[1] = 0.0;
positions[2] = 1.0;
// position 1
positions[3] = 0.0;
positions[4] = (2.0 * Math.sqrt(2.0)) / 3.0;
positions[5] = negativeOneThird;
// position 2
positions[6] = -rootSixOverThree;
positions[7] = negativeRootTwoOverThree;
positions[8] = negativeOneThird;
// position 3
positions[9] = rootSixOverThree;
positions[10] = negativeRootTwoOverThree;
positions[11] = negativeOneThird;
var attributes = new Cesium.GeometryAttributes({
position : new Cesium.GeometryAttribute({
componentDatatype : Cesium.ComponentDatatype.DOUBLE,
componentsPerAttribute : 3,
values : positions
//顶点索引
var indices = new Uint16Array(4 * 3);
// back triangle
indices[0] = 0;
indices[1] = 1;
indices[2] = 2;
// left triangle
indices[3] = 0;
indices[4] = 2;
indices[5] = 3;
// right triangle
indices[6] = 0;
indices[7] = 3;
indices[8] = 1;
// bottom triangle
indices[9] = 2;
indices[10] = 1;
indices[11] = 3;
//包围球
var boundingSphere = new Cesium.BoundingSphere(new Cesium.Cartesian3(0.0,0.0,0.0),1.0);
var geometry = Cesium.GeometryPipeline.computeNormal(new Cesium.Geometry({
attributes: attributes,
indices: indices,
primitiveType: Cesium.PrimitiveType.TRIANGLES,
boundingSphere: boundingSphere
this.attributes = geometry.attributes;
this.indices = geometry.indices;
this.primitiveType = geometry.primitiveType;
this.boundingSphere = geometry.boundingSphere;
//this.boundingSphere = Cesium.BoundingSphere.fromVertices(positions);
var cesiumWidget = new Cesium.CesiumWidget('cesiumContainer');
var scene = cesiumWidget.scene;
var ellipsoid = cesiumWidget.scene.globe.ellipsoid;
//模型矩阵
var modelMatrix = Cesium.Matrix4.multiplyByUniformScale(
Cesium.Matrix4.multiplyByTranslation(
Cesium.Transforms.eastNorthUpToFixedFrame(ellipsoid.cartographicToCartesian(
Cesium.Cartographic.fromDegrees(-100.0, 40.0))),
new Cesium.Cartesian3(0.0, 0.0, 200000.0)),
500000.0);
//四面体的实例
var instance = new Cesium.GeometryInstance({
geometry : Cesium.GeometryPipeline.toWireframe(new TetrahedronGeometry()),
modelMatrix : modelMatrix,
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.WHITE)
//加入场景
scene.primitives.add(new Cesium.Primitive({
geometryInstances : instance,
appearance : new Cesium.PerInstanceColorAppearance({
flat : true,
translucent : false
I want add polygon with self defined indices,to disply all partition in right height. can any one tell me how to add self defined geometry in the latest version or add polygon with self defined indices.thanks!
