Hi, I am new to the Cesium website and looking at using Cesium for a project to show a construction site.
**I wish provide the height data and textures and I see mentioned in the documentation terrain providers. **Do I have to use the providers listed or can I write my own custom terrain provider. Or is there even another way to achieve the same result.
Hi Alan,
Take a look at Cesium ion for processing and streaming your terrain and imagery data, see Getting Started with Cesium ion .
Then, for an overview of how to use Cesium ion along with your CesiumJS application, see the first couple sections of the Cesium Workshop Tutorial .
Thanks!
Gabby
Thank’s Gabby, I’ll take a look
Hi Gabby.
Can you provide any example custom terrain provider implementation for my custom GeoServer? Something like a implementation of TerrainProvider interface. (https://cesiumjs.org/Cesium/Build/Documentation/TerrainProvider.html )?
omar
February 11, 2019, 1:12pm
5
I think the simplest terrain provider implementation I can think of is the Ellipsoid one:
import when from '../ThirdParty/when.js';
import defaultValue from './defaultValue.js';
import defined from './defined.js';
import Ellipsoid from './Ellipsoid.js';
import Event from './Event.js';
import GeographicTilingScheme from './GeographicTilingScheme.js';
import HeightmapTerrainData from './HeightmapTerrainData.js';
import TerrainProvider from './TerrainProvider.js';
* A very simple {@link TerrainProvider} that produces geometry by tessellating an ellipsoidal
* surface.
* @alias EllipsoidTerrainProvider
* @constructor
* @param {Object} [options] Object with the following properties:
* @param {TilingScheme} [options.tilingScheme] The tiling scheme specifying how the ellipsoidal
* surface is broken into tiles. If this parameter is not provided, a {@link GeographicTilingScheme}
* is used.
This file has been truncated. show original
