In the following sample code, you can see a handler for the "mouse move" event.
What i want?
This sample code is working only "move" event. I want the same functionality with the click-through (LEFT_CLICK) event.
I get the following error when I change the event as I want.
Error :
ncaught DeveloperError: windowPosition is undefined.
Error
at new DeveloperError (https://cesiumjs.org/Cesium/Source/Core/DeveloperError.js:43:19)
at Scene.pick (https://cesiumjs.org/Cesium/Source/Scene/Scene.js:3232:19)
at <anonymous>:43:38
at handleMouseUp (https://cesiumjs.org/Cesium/Source/Core/ScreenSpaceEventHandler.js:225:21)
at handlePointerUp (https://cesiumjs.org/Cesium/Source/Core/ScreenSpaceEventHandler.js:624:13)
at HTMLCanvasElement.listener (https://cesiumjs.org/Cesium/Source/Core/ScreenSpaceEventHandler.js:67:13) (on line 3232 of https://cesiumjs.org/Cesium/Source/Scene/Scene.js)
finally, how do I set the color and label div size (margin command in css) of the label? so the background is gray. I want to make it red.
Code example :
selectionIndicator : false,
infoBox : false
var scene = viewer.scene;
var handler;
Sandcastle.addToolbarButton('Pick position', function() {
var modelEntity = viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706),
model : {
uri : '../../SampleData/models/CesiumMilkTruck/CesiumMilkTruck-kmc.gltf'
viewer.zoomTo(modelEntity);
var labelEntity = viewer.entities.add({
label : {
show : false,
showBackground : true,
font : '14px monospace',
horizontalOrigin : Cesium.HorizontalOrigin.LEFT,
verticalOrigin : Cesium.VerticalOrigin.TOP,
pixelOffset : new Cesium.Cartesian2(25, 0),
scaleByDistance : new Cesium.NearFarScalar(1.2e2, 1.5, 1.5e7, 0.5)
// Mouse over the globe to see the cartographic position
handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
handler.setInputAction(function(movement) {
var foundPosition = false;
if (scene.mode !== Cesium.SceneMode.MORPHING) {
var pickedObject = scene.pick(movement.endPosition);
if (scene.pickPositionSupported && Cesium.defined(pickedObject) && pickedObject.id === modelEntity) {
var cartesian = viewer.scene.pickPosition(movement.endPosition);
if (Cesium.defined(cartesian)) {
var cartographic = Cesium.Cartographic.fromCartesian(cartesian);
var longitudeString = Cesium.Math.toDegrees(cartographic.longitude).toFixed(2);
var latitudeString = Cesium.Math.toDegrees(cartographic.latitude).toFixed(2);
var heightString = cartographic.height.toFixed(2);
labelEntity.position = cartesian;
labelEntity.label.show = true;
labelEntity.label.text =
'Lon: ' + (' ' + longitudeString).slice(-7) + '\u00B0' +
'\nLat: ' + (' ' + latitudeString).slice(-7) + '\u00B0' +
'\nAlt: ' + (' ' + heightString).slice(-7) + 'm';
labelEntity.label.eyeOffset = new Cesium.Cartesian3(0.0, 0.0, -cartographic.height * (scene.mode === Cesium.SceneMode.SCENE2D ? 1.5 : 1.0));
foundPosition = true;
if (!foundPosition) {
labelEntity.label.show = false;
Sandcastle.reset = function() {
viewer.entities.removeAll();
handler = handler && handler.destroy();
