Cut complex polygon in terrain
i have polygon with coordinates and my goal is to cut/clip this polygon in terrain. Is it possible to not have terrain in this area? Need only ellipsoid’s surface
i was working around this code:
  function clipPlane(points){
      console.log(points)
      // viewer.entities.removeAll();
     var lol = viewer.entities.add({
                            polygon: {
                                //perPositionHeight: false,
                                // outline: true,
                                // outlineColor: Cesium.Color.RED,
                                outlineWidth: 10,
                                hierarchy: points,
                                clampToGround: true,
                                material: new Cesium.ColorMaterialProperty(Cesium.Color.GREEN.withAlpha(0.8))
    var pointsLength = points.length;
    viewer.zoomTo(lol)
    // Create center points for each clipping plane
    var clippingPlanes = [];
    for (var i = 0; i < pointsLength; ++i) {
    var nextIndex = (i + 1) % pointsLength;
        var midpoint = Cesium.Cartesian3.add(points[i], points[nextIndex], new Cesium.Cartesian3());
        midpoint = Cesium.Cartesian3.multiplyByScalar(midpoint, 0.5, midpoint);
        var up = Cesium.Cartesian3.normalize(midpoint, new Cesium.Cartesian3());
        var right = Cesium.Cartesian3.subtract(points[nextIndex], midpoint, new Cesium.Cartesian3());
        right = Cesium.Cartesian3.normalize(right, right);
        var normal = Cesium.Cartesian3.cross(right, up, new Cesium.Cartesian3());
        normal = Cesium.Cartesian3.normalize(normal, normal);
        // Compute distance by pretending the plane is at the origin
        var originCenteredPlane = new Cesium.Plane(normal, 0.0);
        var distance = Cesium.Plane.getPointDistance(originCenteredPlane, midpoint);
        clippingPlanes.push(new Cesium.ClippingPlane(normal, distance));
    viewer.scene.globe.clippingPlanes = new Cesium.ClippingPlaneCollection({
        planes : clippingPlanes,
        edgeWidth: true,
        edgeColor: Cesium.Color.WHITE,
        enabled : true
but this is not compatible for complex polygons (like mine), only with simple figures like this:
Is there any others possibilities to achieve my goal?
Hi @Dovydas
This Sandcastle demonstrates usage of a complex polygon to clip the terrain. Select the “St. Helens” option in the drop down on the top left.
any ideas why it’s not working properly? Polygon not showed.
my code:
const viewer = new Cesium.Viewer('cesiumContainer', {
terrainProvider: Cesium.createWorldTerrain()
const globe = viewer.scene.globe;
  // For tracking state when switching exampleTypes
  let clippingPlanesEnabled = true;
  let edgeStylingEnabled = true;
  function loadStHelens() {
    // Create clipping planes for polygon around area to be clipped.
    const points= new Cesium.Cartesian3.fromDegreesArray([
    25.30231247043702, 54.737551214420172 ,
    25.310074626511312, 54.737467596240457 ,
    25.317836742485923, 54.737383481327129 ,
    25.317690962283628, 54.732892161288383 ,
    25.325452179885058, 54.732807563631411 ,
    25.333213356927597, 54.732722469334171 ,
    25.340974493174173, 54.732636878402282 ,
    25.340826179941942, 54.728145596942824 ,
    25.34858641740227, 54.728059523609517 ,
    25.348437287671519, 54.72356825275412 ,
    25.348288199180001, 54.719076978275325 ,
    25.3405296765151, 54.719163023163297 ,
    25.340381486289676, 54.714671730843051 ,
    25.340233337035706, 54.710180434902334 ,
    25.347990145852517, 54.710094418447227 ,
    25.347841180985615, 54.705603133097725 ,
    25.340085228737809, 54.70568913534111 ,
    25.332329235549288, 54.705774641447448 ,
    25.33218202453989, 54.70128332413892 ,
    25.332034854219337, 54.696792003212835 ,
    25.339789134948724, 54.696706525356774 ,
    25.339641149426804, 54.692215214933476 ,
    25.339493204799499, 54.687723900889324 ,
    25.339345301051438, 54.683232583224232 ,
    25.331593587238018, 54.683318018728222 ,
    25.331446579520147, 54.678826683330975 ,
    25.331299612414824, 54.674335344315701 ,
    25.339049616131753, 54.674249937030886 ,
    25.338901834929505, 54.669758608502462 ,
    25.331152685906812, 54.669844001682385 ,
    25.331005799980876, 54.665352655430851 ,
    25.323257464849743, 54.665437539102697 ,
    25.323111473728478, 54.660946175215926 ,
    25.322965522923177, 54.656454807713928 ,
    25.322819612418694, 54.65196343659656 ,
    25.322673742199939, 54.647472061863759 ,
    25.314928782335691, 54.647556394401185 ,
    25.307183782436272, 54.647640231847966 ,
    25.299438742737127, 54.647723574198487 ,
    25.299582052272626, 54.65221499046433 ,
    25.291836119418281, 54.652297851393989 ,
    25.284090147220432, 54.652380217134585 ,
    25.276344135914584, 54.65246208768064 ,
    25.268598085736262, 54.652543463026632 ,
    25.260851996921126, 54.652624343167219 ,
    25.260991076756859, 54.657115823429194 ,
    25.253244095641097, 54.657196221634194 ,
    25.245497076345334, 54.65727612454117 ,
    25.245359704322585, 54.652784617810333 ,
    25.2452223702299, 54.648293107493814 ,
    25.245085074053105, 54.643801593591597 ,
    25.244947815777977, 54.639310076103577 ,
    25.237204172836115, 54.639389431277166 ,
    25.237067805434418, 54.634897897102938 ,
    25.229324977840562, 54.634976744276067 ,
    25.229189500841706, 54.630485193502878 ,
    25.221447488623955, 54.630563532836483 ,
    25.213705439252621, 54.630641377341078 ,
    25.205963352962918, 54.630718727011484 ,
    25.198221229990029, 54.630795581842555 ,
    25.190479070569182, 54.630871941829177 ,
    25.190610283535381, 54.63536355645661 ,
    25.182867235054172, 54.635439434119483 ,
    25.175124150581855, 54.635514816846097 ,
    25.16738103035382, 54.635589704631371 ,
    25.167509720257257, 54.640081353033494 ,
    25.159765711385671, 54.640155758156055 ,
    25.159893583464353, 54.644647415286542 ,
    25.160021490854582, 54.649139068861942 ,
    25.160149433569643, 54.653630718882333 ,
    25.160277411622754, 54.658122365347822 ,
    25.160405425027193, 54.662614008258551 ,
    25.160533473796203, 54.667105647614619 ,
    25.168282606353173, 54.667031168733665 ,
    25.168411545272882, 54.671522792232651 ,
    25.168540519819729, 54.676014412174467 ,
    25.176291326517866, 54.675939413003661 ,
    25.176421191936864, 54.680431016998625 ,
    25.176551093245944, 54.684922617433926 ,
    25.176681030458578, 54.689414214309664 ,
    25.176811003588302, 54.693905807625967 ,
    25.169056774546224, 54.693980856372356 ,
    25.161302509810071, 54.694055409109147 , 25.153548209616321, 54.694129465831388 , 25.153675650105676, 54.698621092544748 , 25.153803125829384, 54.703112715707007 ,  25.153930636800691, 54.707604335318287 ,  25.154058183032841, 54.712095951378679 , 25.154185764539037, 54.716587563888289 ,  25.154313381332603, 54.721079172847325 ,  25.162072822298452, 54.721005042663293 ,  25.162201332016956, 54.725496635818658 ,  25.169961595056222, 54.725421996793258 ,  25.177721822307422, 54.725346861184484 ,  25.185482013533509, 54.7252712289974 , 25.193242168497349, 54.725195100237102 ,  25.201002286961916, 54.725118474908662 ,  25.201135121336467, 54.729610002001408 ,  25.201267992461197, 54.734101525527386 ,  25.201400900349888, 54.738593045486624 , 25.201533845016403, 54.743084561879286 ,  25.201666826474565, 54.747576074705449 ,  25.209431199474839, 54.747498889045929 , 25.209565076705012, 54.751990385543614 ,  25.217330271614969, 54.75191269007172 ,  25.217465045092247, 54.756404170153289 ,  25.225231061883914, 54.756325964707166 ,  25.232997041129387, 54.756247262139091 , 25.233133570728786, 54.760738712702626 ,  25.240900371575911, 54.76065949992158 ,  25.248667134387244, 54.760579789946988 ,  25.248805421016897, 54.765071210652494 ,  25.256573005149228, 54.764990990226202 , 25.256712189899215, 54.769482394082054 ,  25.264480595323668, 54.769401663042196 , 25.272248961969908, 54.769320434660607 , 25.280017289600138, 54.769238708942822 ,  25.28778557797645, 54.769156485894214 ,  25.295553826860939, 54.769073765520446 , 25.295410343168474, 54.764582429229691 ,  25.295266899190711, 54.760091089337905 , 25.303033389095255, 54.760007899160499 ,  25.30288912554872, 54.755516569421076 ,  25.310654716262256, 54.755432895929481 ,  25.310509633622207, 54.75094157641837 ,  25.310364591127097, 54.746450253299912 ,  25.302600718207998, 54.74653389912946 ,  25.302456574383807, 54.742042558577054 ,  25.30231247043702, 54.737551214420172 ])
    const points4= new Cesium.Cartesian3.fromDegreesArray([
    const clippingPlanes = [];
    for (let i = 0; i < pointsLength; ++i) {
      const nextIndex = (i + 1) % pointsLength;
      let midpoint = Cesium.Cartesian3.add(
        points[i],
        points[nextIndex],
      console.log(midpoint)
        midpoint,
        0.5,
        midpoint
      const up = Cesium.Cartesian3.normalize(
        midpoint,
      console.log(up)
      let right = Cesium.Cartesian3.subtract(
        points[nextIndex],
        midpoint,
      let normal = Cesium.Cartesian3.cross(
        right,
        up,
      console.log("////////////////////////////////////////")
      console.log(normal)
      const originCenteredPlane = new Cesium.Plane(normal, 0.0);
      const distance = Cesium.Plane.getPointDistance(
        midpoint
      planes: clippingPlanes,
      edgeWidth: edgeStylingEnabled ? 1.0 : 0.0,
      enabled: clippingPlanesEnabled,
    globe.backFaceCulling = true;
    globe.showSkirts = true;
  loadStHelens();
i also tried with smaller amount of points and didn’t get needed results as well.
First of all i was not able to see polygon from coordinates area, only could see something when drastically zoomed out (white dot):
from other planet side i was able to zoom and see polygon:
but when i use a lot of points (in my code), can’t even get these results like with 4 points.
Polygon has to be convex since clippingPlanes (used under the hood to convert polyline to a set of clipping planes) have infinite extent.
