I am trying to place two cylinders, one top of each other, on the surface of the globe. The bottom cylinder should be on the surface of the earth. Each cylinder represents a ‘measure’, so their ‘height’ varies according to the corresponding value. However, the cylinders are either overlapping or there is some gap in between them. I think I am going wrong with the cylinder positions. Here is the code:
var bottomCylinderHeight = Value1 * 1000; //1000 is the scale factor
var bottomCylinder = entities.getOrCreateEntity(“1”);
bottomCylinder.position = Cesium.Cartesian3.fromDegrees(-100.5, 62.4, 0);
bottomCylinder.cylinder = new Cesium.CylinderGraphics({
length: bottomCylinderHeight,
topRadius: 500.0,
bottomRadius: 500.0,
outline: false,
outlineColor: Cesium.Color.BLUE,
outlineWidth: 4,
material: new Cesium.ColorMaterialProperty(Cesium.Color.BLUE)
var topCylinderHeight = Value2 * 1000;// 1000 is the scale factor
var topCylinder = entities.getOrCreateEntity(“2”);
topCylinder .position = Cesium.Cartesian3.fromDegrees(-100.5, 62.4, bottomCylinderHeight );
topCylinder.cylinder = new Cesium.CylinderGraphics({
length: topCylinderHeight ,
topRadius: 500.0,
outline: false,
outlineColor: Cesium.Color.RED,
outlineWidth: 4,
material: new Cesium.ColorMaterialProperty(Cesium.Color.RED)
Thanks
Kiran
