CZML model Path disappears
I am doing a czml with two paths, when the two paths do not end at the same time the model disappears. How can I fix it?
I use Sandcastle 1.37 for test. This is my code:
var czml = [{
“id” : “document”,
“name” : “CZML Path”,
“version” : “1.0”,
“clock”: {
“interval”: “2012-08-04T10:00:00Z/2012-08-04T10:02:00Z”,
“currentTime”: “2012-08-04T10:00:00Z”,
“multiplier”: 10,
“range” : “CLAMPED”,
“step” : “SYSTEM_CLOCK_MULTIPLIER”
“id” : “path”,
“name” : “path with GPS flight data”,
“description” : “
Hang gliding flight log data from Daniel H. Friedman.
Icon created by Larisa Skosyrska from the Noun Project
“availability” : “2012-08-04T10:00:00Z/2012-08-04T10:02:00Z”,
“path” : {
“material” : {
“polylineOutline” : {
“color” : {
“rgba” : [255, 0, 255, 255]
“outlineColor” : {
“rgba” : [0, 255, 255, 255]
“outlineWidth” : 5
“width” : 8,
“leadTime” : 10,
“trailTime” : 1000,
“resolution” : 5
“model”: {
“gltf” : “…/…/SampleData/models/CesiumAir/Cesium_Air.glb”,
“scale” : 2.0,
“minimumPixelSize”: 128
“position” : {
“epoch” : “2012-08-04T10:00:00Z”,
“cartographicDegrees” : [
0,-122.93797,39.50935,1776,
10,-122.93822,39.50918,1773,
20,-122.9385,39.50883,1772,
30,-122.93855,39.50842,1770,
40,-122.93868,39.50792,1770,
50,-122.93877,39.50743,1767,
60,-122.93862,39.50697,1771,
70,-122.93828,39.50648,1765,
80,-122.93818,39.50608,1770,
90,-122.93783,39.5057,1754,
100,-122.93777,39.50513,1732
“id” : “path2”,
“description” : “
“path” : {
“material” : {
“color” : {
“outlineColor” : {
“outlineWidth” : 5
“width” : 8,
“leadTime” : 10,
“trailTime” : 1000,
“resolution” : 5
“model”: {
“scale” : 2.0,
“position” : {
0,-122.93197,39.50935,1776,
10,-122.93922,39.50918,1773,
20,-122.9395,39.50883,1772,
30,-122.93955,39.50842,1770,
40,-122.93968,39.50792,1770,
50,-122.93977,39.50743,1767,
60,-122.93962,39.50697,1771,
70,-122.93928,39.50648,1765,
80,-122.93918,39.50608,1770,
90,-122.93883,39.5057,1754,
100,-122.93877,39.50513,1732,
110,-122.9393,39.50458,1727,
120,-122.939815,39.50415,1717
var terrainProvider = new Cesium.CesiumTerrainProvider({
url : ‘https://assets.agi.com/stk-terrain/v1/tilesets/world/tiles’,
requestVertexNormals : true
terrainProvider : terrainProvider,
baseLayerPicker : false
viewer.dataSources.add(Cesium.CzmlDataSource.load(czml)).then(function(ds) {
viewer.trackedEntity = ds.entities.getById(‘path’);
I added another item in the list of positions for the first path and that works:
var czml = [{
"id" : "document",
"name" : "CZML Path",
"version" : "1.0",
"clock": {
    "interval": "2012-08-04T10:00:00Z/2012-08-04T10:02:00Z",
    "currentTime": "2012-08-04T10:00:00Z",
    "multiplier": 10,
    "range" : "CLAMPED",
    "step" : "SYSTEM_CLOCK_MULTIPLIER"
"id" : "path",
"name" : "path with GPS flight data",
"description" : "<p>Hang gliding flight log data from Daniel H. Friedman.<br>Icon created by Larisa Skosyrska from the Noun Project</p>",
"availability" : "2012-08-04T10:00:00Z/2012-08-04T10:02:00Z",
"path" : {
    "material" : {
        "polylineOutline" : {
            "color" : {
                "rgba" : [255, 0, 255, 255]
            "outlineColor" : {
                "rgba" : [0, 255, 255, 255]
            "outlineWidth" : 5
    "width" : 8,
    "leadTime" : 10,
    "trailTime" : 1000,
    "resolution" : 5
"model": {
    "gltf" : "../../SampleData/models/CesiumAir/Cesium_Air.glb",
    "scale" : 2.0,
    "minimumPixelSize": 128
"position" : {
    "epoch" : "2012-08-04T10:00:00Z",
    "cartographicDegrees" : [
        100,-122.93777,39.50513,1732,
        120,-122.93777,39.50513,1732
"id" : "path2",
"path" : {
    "material" : {
            "color" : {
            "outlineColor" : {
            "outlineWidth" : 5
    "width" : 8,
    "leadTime" : 10,
    "trailTime" : 1000,
    "resolution" : 5
“model”: {
    "scale" : 2.0,
"position" : {
I’m not sure why the model was disappearing in the first place though.
Gabby
Thanks, works fine.
