CZML, time-based property changes of entities
spent HOURS trying to understand the concept of CZML - seems only a very verbose approach would be possible if toi change the properties of specific entities over time
have not found out how to use for example variables to store the static properties - just once…
or else there may need to be an altogether different approach when trying to achieve the evolution of an object at static position, but changing properties…
see attached file
visualize changes over time
1.66, Mac OPSX, Safari
thanks for any pointer!
cesiumTime2.html (1.45 KB)
