Defining new Cesium.ProviderViewModel with url from String array
Cesium version 1.21
I am reading json from a file and extracting URLs to add as ProviderViewModels in the baseLayerPicker. Currently, the creationFunction is executed only after the user selects that layer. At that point, I cannot get the layer that they have chosen to retrieve the URL. Below is the code
int i = 0;
for(i = 0; i < jsonImageServers.length; i++){
imageryViewModels.push(new Cesium.ProviderViewModel({
tooltip : jsonImageServers[i].tooltip,
iconUrl : Cesium.buildModuleUrl(‘Widgets/Images/ImageryProviders/img.png’),
creationFunction : function() {
return new Cesium.ArcGisMapServerImageryProvider({
url: jsonImageServers[i].url,
enablePickFeatures: false,
ellipsoid: Cesium.Ellipsoid.WGS84
This code breaking on the highlighted line inside the creationFunction after the user selects a layer from the picker. At that point, ‘i’ is not the correct value and I cannot retrieve the correct URL from the array. Anyone ever run into this issue? I cannot have a user go into the Javascript code to hard code their imagery server URLs.
This is a classic JavaScript closure error, and not related to Cesium - all functions refer to the same i variable, not the value of i at the time the function is created.
This might help:
http://stackoverflow.com/questions/750486/javascript-closure-inside-loops-simple-practical-example
Thanks for the link Scott, I had not run into this before. Was able to fix my code using the link.
