I want to delete a CZML with callbacks set.
For polylines, it is not possible to delete.
In the case of ellipsoid, it was possible to delete it.
How do you handle the case of a polyline?
Polyline code
var DataSource = new Cesium.CzmlDataSource();
let loadedPromise = DataSource.load("../../SampleData/simple.czml");
viewer.dataSources.add(DataSource);
var entities = [];
Sandcastle.addToolbarButton("Remove Polyline", function () {
let removeData = viewer.dataSources.getByName("document_name");
viewer.dataSources.remove(removeData[0]);
let doc = {
version: "1.0",
entities.push(doc);
const entity = {
polyline: {
positions: {
cartesian : [-3499152.949946318, 4532113.931097018, 2800650.164501517,3499152.949946318,4532113.931097018,2800650.164501517],
width: 1.0,
material: {
color: {
rgba: [255, 255, 255, 255]
arcType: "NONE",
entities.push(entity);
loadedPromise.then(function () {
let dataSourcePromise = Cesium.CzmlDataSource.load(entities);
viewer.dataSources.add(dataSourcePromise).then(
function(dataSource){
let entity1 = DataSource.entities.getById("Satellite/Geoeye1");
let entity2 = DataSource.entities.getById("Satellite/Molniya_1-92");
let entity3 = dataSource.entities.getById("POLYLINE");
entity3.polyline.positions = new Cesium.CallbackProperty(function () {
let time = viewer.clock.currentTime;
let pos1 = entity1.position.getValue(time);
let pos2 = entity2.position.getValue(time);
let arr = [];
arr.push( pos1 );
arr.push( pos2 );
return arr;
}, false);
return dataSource;
Screen
Error when deleting a polyline
Ellipsoid code
var entities = [];
Sandcastle.addToolbarButton("Remove Ellipsoid", function () {
let removeData = viewer.dataSources.getByName("ellipsoid_czml");
let doc = {
version: "1.0",
entities.push(doc);
const entity = {
position: {
cartesian : [-3499152.949946318, 4532113.931097018, 2800650.164501517]
orientation: undefined,
ellipsoid: {
radii: {
cartesian: [ 1000000, 1000000, 1000000 ]
material: {
solidColor: {
color: {
rgba: [255,255,255,255]
outline: true,
let entity2 = dataSource.entities.getById("ELLIPSOID");
entity2.position = new Cesium.CallbackProperty(function () {
let pos = entity1.position.getValue(time);
return pos;
}, false);
return dataSource;
