Destroy throws render error
Hello. I built an application using Resium which uses several models, tilesets, polyline and polygons.
All are components under the Viewer component. What is the right way to exit from the whole Cesium component?
When i try to destroy the models i get this error:
DeveloperError: This object was destroyed, i.e., destroy() was called.
Error
at new DeveloperError (http://localhost:3000/cesium/Cesium.js:82:23)
at Model.throwOnDestroyed (http://localhost:3000/cesium/Cesium.js:29066:23)
at PrimitiveCollection.update (http://localhost:3000/cesium/Cesium.js:131116:31)
at updateAndRenderPrimitives (http://localhost:3000/cesium/Cesium.js:237416:31)
at executeCommandsInViewport (http://localhost:3000/cesium/Cesium.js:237250:17)
at Scene.updateAndExecuteCommands (http://localhost:3000/cesium/Cesium.js:237058:17)
at render (http://localhost:3000/cesium/Cesium.js:237721:19)
at tryAndCatchError (http://localhost:3000/cesium/Cesium.js:237740:17)
at Scene.render (http://localhost:3000/cesium/Cesium.js:237815:17)
at CesiumWidget.render (http://localhost:3000/cesium/Cesium.js:250280:29)
Thank you very much
Not sure if this is still relevant, but for anyone who lands here due to searching for that specific error:
PrimitiveCollection.remove() already calls Primitive.destroy(). Calling destroy() again results in that error.
This behaviour can be toggled by setting destroyPrimitives to true or false.
