Are there any developers here with experience in resium
I’m building a big app all based on react and resium. i’m getting trouble with the 3D tilesset. the component’s url doesnt receive anything and nothing happens in the component. i see the viewer but none of the dunctions are fired from the Cesium3Dtileset component.
looked for solutions in webpack and didnt find any.
const tileSet = () => {
const ref = useRef(null);
return
<Cesium3DTileset
url="./tileset.json"
onAllTilesLoad={(…args) => console.log(“onAllTilesLoad”, …args)}
onInitialTilesLoad={(…args) => console.log(“onInitialTilesLoad”, …args)}
onTileFailed={(…args) => console.log(“onTileFailed”, …args)}
onTileLoad={(…args) => console.log(“onTileLoad”, …args)}
onTileUnload={(…args) => console.log(“onTileUnload”, …args)}
onReady={tileset => {
console.log(“onReady”, tileset);
ref.current.cesiumElement.zoomTo(tileset);
Did you get any help with this yet?
Nope. Not yet
בתאריך יום ה׳, 8 ביולי 2021, 12:11, מאת Pontus Nilsson via Cesium Community ‏<cesium@discoursemail.com>:
So you are importing your component inside the viewer and nothing fires?
No. My problem is with destroying the viewer, models and primitives. I allways get an error which crashes my app.
The models are created by resium Model component.
In general. I combign resium and cesiums javascript so i trying to find the right way to leave the cesium enviroment without getting any errors
בתאריך יום ה׳, 8 ביולי 2021, 12:31, מאת Pontus Nilsson via Cesium Community ‏<cesium@discoursemail.com>:
What error is it? so you are destroying the viewer with viewer.destroy() ? In general i use resium components and for the code and functions i use the viewer variable that you create. Not sure i can help you but will try.
yes. this is exacly how i use resium too. i attached the error.
I think it happens because the viewer is destroyed and then a functionality is called in the Model component in it. which i know doesnt make sense because the model component is inside the viewer compoment. so i tried “viewer.pimitives.removeAll” before destroying the viewer and that doesnt help.
Can you share the right way to close a Resium environment with Model components inside it?
I dont know the right way to close a Resium environment with Model components inside it.
In my head this should work:
const App = ( ) => {
  let viewer = null;
  handleDestroy = () => {
    if (viewer) {
      viewer.destroy();
  return (
  <Viewer ref={e => { viewer = e ? e.cesiumElement : null; }}>
    <button onClick={handleDestroy}>Destroy!</button>
  </Viewer>
But i doubt this will work if you have more resium components inside the viewer already.
I did some research i didn’t find much but maybe this could help you a bit:
Thank you. i managed to do a work arround. i first remove all the Models components and then destroy. sothe errors are gone:)
Nice! :slight_smile:
