While implementing the cesium program through React, the .glb file was successfully loaded, but the 3Dtileset failed to load. An attempt was made to load a 3Dtileset locally without the backend server being configured yet.
So my question is, is a backend server required to load a locally stored 3D Tilesset in Cesium js? Or, I wonder if there is a grammatical error. The error coming from the current code is below. Uncaught TypeError: Cannot set properties of undefined (setting ‘_url’)
import React from 'react'; import { Viewer, Entity } from 'resium';
import { Cartesian3, Color, IonResource, Cesium3DTileset, createWorldTerrain } from 'cesium'; import 'cesium/Build/Cesium/Widgets/widgets.css';
function App() {
return (
<div style={{ height: "100vh", width: "100%" }}> <Viewer full terrainProvider={createWorldTerrain({ requestWaterMask: true, requestVertexNormals: true, })} > {/* 추가 엔티티 */} <Entity name="Sample Point" position={Cartesian3.fromDegrees(126.9780, 37.5665, 100)} // 서울 좌표 point={{ pixelSize: 10, color: Color.BLUE }} description="This is a sample point." />
{/* GLB 모델 엔티티 */}
<Entity
name="Ground Vehicle"
model={{
uri: './Cesium/Assets/GroundVehicle.glb', // public 폴더에 파일을 넣은 경우 상대경로로 접근
minimumPixelSize: 128,
maximumScale: 20000
{/* 3D Tileset 엔티티 */}
<Cesium3DTileset
url={'./Cesium/Assets/baekma_second/tileset.json'} // 3D Tileset의 URL 경로
maximumScreenSpaceError={16} // 화면 공간 오류를 설정하여 성능을 조절
skipLevels={0}
</Viewer>
</div>
export default App;
