I am working on this Cesium Sandcastle
Occassionally, I will receive this error: "DeveloperError: Expected value to be greater than or equal to 0.0125, the actual value was 0"
I believe it pertains to the polyline being created, but I am not sure. The error comes up pretty randomly so I am struggling to debug it. I was hoping someone could look at this sandcastle and see where the problem would come up so I can add an error check.
It’s also worth noting that I am not positive these 3 points being displayed will reproduce the error. I have been using a ton of different points with different initial conditions. Some throw the error faster than others.
Thank you for any help you can offer.
here is a copy of the error message happening in my application. It is running the same code as in the sandcastle
I found the condition that was throwing the error and added a check for it:
pair.line = this.viewer.entities.add({
polyline: {
// This callback updates positions each frame.
positions: new CallbackProperty(function (time, result) {
//THIS CONDITION CHECKS IF LATITUDES ARE INVERSES
// IF THEY ARE, DONT UPDATE POSITION THIS TIME
if (
pair.point1.posDegrees[1] * -1 ===
pair.point2.posDegrees[1]
return;
return Cartesian3.fromDegreesArrayHeights(
pair.point1.posDegrees[0],
pair.point1.posDegrees[1],
pair.point1.height,
pair.point2.posDegrees[0],
pair.point2.posDegrees[1],
pair.point2.height,
Ellipsoid.WGS84,
result
}, false),
width: this.lineWidth,
material: new Color(255, 255, 255, 255),
The all caps comment explains how I fixed it
