I’ve been Developing an Application that shows Camera Fields of View. I had it working but it was slowing down. So I slightly changed when I was querying data, and now my datasources won’t show on the browser.
So I’ve debugged it down to the CZML, It appears that everything is in place for it to work (i.e. the Camera FOV vertex data is in the Cartesian3 Array), but its not showing up.
Small Snippet of my CZML
“id” : “C2F5”,
“name”: “Dynamic Polygon with Reference Properties”,
“availability”:“2012-08-04T16:00:00Z/2012-08-04T17:00:00Z”,
“polygon”: {
“positions”: {
“references”: [
“c2v1#position”,
“c2v2#position”,
“c2v3#position”,
“c2v4#position”
“perPositionHeight” : true,
“material” : {
“solidColor” : {
“color”: {
“rgba” : [255, 0, 0, 50]
“id”: “c1v0”,
“position”: {
“interpolationAlgorithm”: “LINEAR”,
“interpolationDegree”: 1,
“interval” : “2012-08-04T16:00:00Z/2012-08-04T17:00:00Z”,
//“epoch” : “2012-08-04T16:00:00Z”,
“cartographicDegrees”: [
“id”: “c1v1”,
“position”: {
Some Setup Code
imageryProvider : new Cesium.ArcGisMapServerImageryProvider({
url : ‘http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer’
baseLayerPicker : false
//Initialize all of the Data Sources
var DS_901 = new Cesium.CzmlDataSource(‘901czml’);
var DS_layer1 = new Cesium.CzmlDataSource(‘layer1czml’);
//Load the Data sources to the viewer obj
viewer.dataSources.add(DS_901.load(czml901));
viewer.dataSources.add(DS_layer1.load(camera_data)); //must load camera data last, due to global clock initialization
The HTTP Call that grabs the Data
function processL1() {
var xhttp4 = new XMLHttpRequest();
xhttp4.onreadystatechange = function() {
if (xhttp4.readyState === 4 && xhttp4.status === 200) {
console.log(xhttp4.response);
// Execute two functions upon recieving data
//find records to add to data set
//add records to relevant data set
xhttp4.response.forEach(function(element) {
//console.log(element);
var current = element;//JSON.parse(element);
var timestamp = current.data.timestamp;
//get availibility string from timestamp
var tempISO = new Date(timestamp).toISOString();
//console.log(current);
if (current.data.camera_id === 1) {
//console.log(current.data.vertices);
convertheights(current);
camera_data[11].position.cartographicDegrees.push(tempISO, current.data.vertices.v0.x, current.data.vertices.v0.y, current.data.vertices.v0.z);
camera_data[12].position.cartographicDegrees.push(tempISO, current.data.vertices.v1.x, current.data.vertices.v1.y, current.data.vertices.v1.z);
camera_data[13].position.cartographicDegrees.push(tempISO, current.data.vertices.v2.x, current.data.vertices.v2.y, current.data.vertices.v2.z);
camera_data[14].position.cartographicDegrees.push(tempISO, current.data.vertices.v3.x, current.data.vertices.v3.y, current.data.vertices.v3.z);
camera_data[15].position.cartographicDegrees.push(tempISO, current.data.vertices.v4.x, current.data.vertices.v4.y, current.data.vertices.v4.z);
if (camC.count > 5) {
camera_data[11].position.cartographicDegrees.splice(0, 4);
camera_data[12].position.cartographicDegrees.splice(0, 4);
camera_data[13].position.cartographicDegrees.splice(0, 4);
camera_data[14].position.cartographicDegrees.splice(0, 4);
camera_data[15].position.cartographicDegrees.splice(0, 4);
camC.count++;
else if (current.data.camera_id === 2) {
camera_data[16].position.cartographicDegrees.push(tempISO, current.data.vertices.v0.x, current.data.vertices.v0.y, current.data.vertices.v0.z);
camera_data[17].position.cartographicDegrees.push(tempISO, current.data.vertices.v1.x, current.data.vertices.v1.y, current.data.vertices.v1.z);
camera_data[18].position.cartographicDegrees.push(tempISO, current.data.vertices.v2.x, current.data.vertices.v2.y, current.data.vertices.v2.z);
camera_data[19].position.cartographicDegrees.push(tempISO, current.data.vertices.v3.x, current.data.vertices.v3.y, current.data.vertices.v3.z);
camera_data[20].position.cartographicDegrees.push(tempISO, current.data.vertices.v4.x, current.data.vertices.v4.y, current.data.vertices.v4.z);
camera_data[16].position.cartographicDegrees.splice(0, 4);
camera_data[17].position.cartographicDegrees.splice(0, 4);
camera_data[18].position.cartographicDegrees.splice(0, 4);
camera_data[19].position.cartographicDegrees.splice(0, 4);
camera_data[20].position.cartographicDegrees.splice(0, 4);
camera_data[0].clock.multiplier = 1;
//DS_layer1.process(camera_data);
//move timestamp forward --> doing this after adding records
prevTime.time = prevTime.time + 1000;
console.log(camera_data);
console.log(viewer);
console.log(tReset.count);
//console.log(bounding_boxes);
xhttp4.responseType = ‘json’;
xhttp4.open(“GET”, “http://10.130.36.13:6824/processL1/” + (prevTime.time + 1000) + “/” + prevTime.time);
xhttp4.send();
tReset.count++;
Here is some Debugging content from the Inspector
Why am I not seeing this on my viewer?
Cesium 1.41 ->> Version
