trouble in loading example czml file
I read the other posts about loading czml file and would like to try one out myself. I downloaded the simple.czml file from https://github.com/AnalyticalGraphicsInc/cesium/tree/master/Apps/CesiumViewer/Gallery
Then I used the sample html code from other posts. (see below). When running this Simple_czml.html file on FireFox, I got the error :
[15:02:17.430] uncaught exception: DeveloperError: dataSourceCollection is required.
Please help.
Thanks
if you use a Cesium Viewer instead of the Cesium Widget, it works right out of the box.
See http://pastebin.com/uZLNFGLe
thank you for your reply. I still have problem. The page is blank. Console shows no warning or error, just one line showing the location of the html file.
Do I still use the widget.css and cesium.js? Below is the code. I am not sure how to paste the code with color.
Thank you.
Hello World! @import url(Cesium-full-b25/Build/Cesium//Widgets/widget.css);
  #cesiumContainer {
      position: absolute;
      top: 0;
      left: 0;
      height: 100%;
      width: 100%;
      margin: 0;
      overflow: hidden;
      padding: 0;
      font-family: sans-serif;
  body {
      padding: 0;
      margin: 0;
      overflow: hidden;
        animation : false,
        baseLayerPicker : false,
        fullscreenButton : false,
        geocoder : false,
        homeButton : false,
        sceneModePicker : false,
        timeline : false,
        infoBox : false,
        //Use standard Cesium terrain
        terrainProvider : new Cesium.CesiumTerrainProvider({
            url : 'http://cesiumjs.org/smallterrain',
            credit : 'Terrain data courtesy Analytical Graphics, Inc.'
    //Allow users to zoom and follow objects loaded from CZML by clicking on it.
    viewer.extend(Cesium.viewerDynamicObjectMixin);
    var czmlSource = new Cesium.CzmlDataSource();
    czmlSource.loadUrl('Cesium-full-b25/Apps/CesiumViewer/Gallery/simple.czml');
    viewer.dataSources.add(czmlSource);
Found my own mistake. I am missing before the .
