I would like to add example.czml file to the viewer. After open the Cesium I don’t get any effect and errors. Below example of my code.
I add only that, when I write code from example.czml file as script in index.html file (var czml = […] and then CzmlDataSource.load(czml) ) everything works ok.
example.czml file -
“id” : “document”,
“name” : “Wstrzasy”,
“version” : “1.0”
“id” : “Wstrzas_1”,
“availability”: “2017-01-02T00:00:01Z/2017-01-02T23:59:00Z”,
“name” : “Wstrzas_1”,
“description”: “
To jest kulka
Magnitiuda: 3.3
“position” : {
“cartographicDegrees” : [18.9144, 50.2368, 100]
“model”: {
“gltf” : “…/data/Kula.glb”,
“scale” : 3.3,
“minimumPixelSize”: 64
“id” : “Wstrzas_2”,
“availability”: “2017-01-03T00:00:01Z/2017-01-03T23:59:00Z”,
“name” : “Wstrzas_2”,
“description”: “
To jest kulka
Magnitiuda: 2.6
“position” : {
“cartographicDegrees” : [19.0407, 50.2295, 100]
“model”: {
“scale” : 2.6,
and code from my index.html file -
Can anybody tell what is wrong? I’m new in using CZML files.
Thanks for help.
Lukas
