As the title, is it possible have different color for different polygon inside the same placemark on a KML file?
For example:
For example:
To be more clear…
KML MultiGeometry is what you want. However, this will get broken down into individual entities when loaded into Cesium (since the Entity API does not support multi-geometry yet).
If your main goal is Cesium visualization, I would recommend CZML (or the Entity API directly) over KML. CZML will continue to evolve and improve while the KML standard is a dead-end.
The problem is that when i insert the tag inside a its characteristics is spreading throughout the placemark.
Also if i use an “id” for the different styles and i recalling them using in each individual polygon or multigeometry nothing change.
Only one color for all placemark.
