I have 15-16.000 entities stored in the same CZML file.
When i try to load them, Cesium automatically freeze all the widget on the screen (clock, animation, etc…), and comes back to work once all the entities were loaded.
I can cover this behavior by implementing a loading dialog, but i would like to render a single entity once loaded, not all the CZML at same time.
This is how i load the CZML:
loadedCZML = new Cesium.CzmlDataSource();
loadedCZML.load(pathCzml.satCZMLpath[i].CZMLFile).then(function(loaded) {
viewer.dataSources.add(loadedCZML).then(function(loaded){
console.log("caricato");
}).otherwise(function(error) {
console.log(“mi sà di no”);
console.log(error);
And that is an extract of my CZML file:
“id”:“document”,
“name”:“test_document”,
“version”:“1.0”
“id”:“00001”,
“name”:“Entity_1”,
“description”:“desc”,
“point”:{
"color":{
"rgbaf":[
1,1,0,1
"outlineColor":{
"rgbaf":[
0,0,0,1
"outlineWidth":2,
"pixelSize":4,
"show":true
“path”:{
"width":1,
"trailTime":7969,
"leadTime":0,
"show":false
“position”:{
"referenceFrame":"INERTIAL",
"epoch":"2016-04-25T23:59:03.15600000000268Z",
"cartesian":[
positions....
"interpolationAlgorithm":"LAGRANGE",
"interpolationDegree":2
There is a way to do it? Should i use Entity API instead of CZML?
Thank you,
Federico.
