I need to display terrains in UnrealEngine using the Cesuim plugin.
My terrain should never be downloaded from the internet, but from a local machine. If I understood correctly, it is possible with a local server.
I found an example server here: GitHub - CesiumGS/3d-tiles-samples: Sample tilesets for learning how to use 3D Tiles
I managed to display a dragon with this example. If I want to display a complete terrain with raster, elevation, objects, …
Here are my questions:
Can I use this server sample with my terrains, or is there a better application or method?
Where can I find good documentations on this? (tutorial, configurations,…)
Are there any limitations to using my own server?
My lands are in the form of CDB. I found this converter to 3DTiles here: GitHub - CesiumGS/cdb-to-3dtiles: Convert CDB to 3D Tiles
Is this the reference software to do this job? Is there a Windows version?
Thank you
