Does Cesium For Unity support publishing the WebGL version in Unity?
yes! I’ve not tested latest version yet!
check this out!
I’m using Unity 6000.0.58f2 and cannot build for WebGL.
@Soulfire Are you using version 1.20.0? If so, can you share any errors you’re running into?
Yes, I’m using version 1.20, and the build error is as follows:
Build completed with a result of ‘Failed’ in 388 seconds (387504 ms)
Building Library\Bee\artifacts\WebGL\build\debug_WebGL_wasm\build.js failed with output:
E:\Work\TaiCang\Unity\TaicangVisualLow>set MYDIR=D:\Program Files\Unity 6000.0.58f2\Editor\Data\PlaybackEngines\WebGLSupport\BuildTools\Emscripten\emscripten\
E:\Work\TaiCang\Unity\TaicangVisualLow>goto FOUND_MYDIR
wasm-ld: error: Library/PackageCache/com.cesium.unity@57778A6EB39E/Plugins/WebGL/libCesiumForUnityNative-Runtime.a(CesiumCreditSystem.cpp.o): undefined symbol: __wasm_lpad_context
wasm-ld: error: Library/PackageCache/com.cesium.unity@57778A6EB39E/Plugins/WebGL/libCesiumForUnityNative-Runtime.a(CesiumCreditSystem.cpp.o): undefined symbol: _Unwind_CallPersonality
wasm-ld: error: too many errors emitted, stopping now (use -error-limit=0 to see all errors)
emcc: error: ‘“D:/Program Files/Unity 6000.0.58f2/Editor/Data/PlaybackEngines/WebGLSupport/BuildTools/Emscripten/llvm\wasm-ld.exe” @C:\Users\PR47D6~1.ADM\AppData\Local\Temp\emscripten_0re38ho3.rsp.utf-8’ failed (returned 1)
UnityEditor.EditorApplication:Internal_CallDelayFunctions ()
Hi @Soulfire,
@Kevin_Ring just wrote up some documentation with build instructions for various platforms, including building for the web. Could you check it out below? I think your errors are covered by some instructions in the doc.
Yeah, to fix those errors, you’ll need to enable “Enable Native C/C++ Multithreading” in the Player Settings.
Thank you very much. The WebGL build was successful, but it runs very sluggishly and laggy during runtime.
