I’ve been creating a donut, like below using the EllipseGeometryLibrary as explained in this post: How on earth do I draw a donut? (granted it’s from 2016):
Although it works, I can’t find any documentation behind it. Are there plans to deprecate? If so, how can I achieve the same results?
The code for the polygon with holes starts on line 65. The example is also in the documentation for PolygonGeometry. This is an example with a square polygon shape, but you can also apply the same logic to a circular shape to create the donut above.
