Hey there,
I want to draw a line by clicking once to start the line and then click a second time to draw a line between these two points. Whats important to me is, that the temporary line from the first click to the current mouse position is drawn as well.
What I have so far is this:
var screenSpaceEventHandler = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
// Function to add a point at the mouse position
function addPoint(position) {
point = viewer.entities.add({
position: position,
point: {
pixelSize: 5,
color: Cesium.Color.RED
// Event handler for left click
screenSpaceEventHandler.setInputAction(function(click) {
// get position of click
var clickPosition = viewer.camera.pickEllipsoid(click.position);
// add point at initial click position
addPoint(clickPosition);
// Event handler for mouse movement
screenSpaceEventHandler.setInputAction(function(movement) {
// get position of mouse
var mousePosition = viewer.camera.pickEllipsoid(movement.endPosition, viewer.scene.globe.ellipsoid, mousePosition);
// use callback property to add a point at the position of the mouse cursor
var point = viewer.entities.add({
position: new Cesium.CallbackProperty(function(time, result) {
return mousePosition
}, false),
point: {
pixelSize: 5,
// create an empty array where the coordinates of the line will be stored
var lineArray =
// convert mouse and click position to lon/lat coordinates and add them to the array
var cartographicMouse = Cesium.Ellipsoid.WGS84.cartesianToCartographic(mousePosition);
var cartographicClick = Cesium.Ellipsoid.WGS84.cartesianToCartographic(clickPosition);
startPoint.longitude = cartographicClick.longitude;
startPoint.latitude = cartographicClick.latitude;
endPoint.longitude = cartographicMouse.longitude;
endPoint.latitude = cartographicMouse.latitude;
var x = Cesium.Math.toDegrees(cartographicMouse.longitude);
var y = Cesium.Math.toDegrees(cartographicMouse.latitude);
lineArray.push(x);
lineArray.push(y);
var x = Cesium.Math.toDegrees(cartographicClick.longitude);
var y = Cesium.Math.toDegrees(cartographicClick.latitude);
lineArray.push(x);
lineArray.push(y);
// use callback property to get cartesian coordinates for the line; if there is an existing line remove it, store in varible
var linePosition = new Cesium.CallbackProperty(function(time, result) {
if (typeof tempLine !== 'undefined') {
viewer.entities.remove(tempLine);
return new Cesium.Cartesian3.fromDegreesArray(lineArray)
}, false)
// draw tempLine
var tempLine = viewer.entities.add({
polyline: {
positions: linePosition,
width: 5,
material: Cesium.Color.RED
// Event handler for second click; draw line with position from variable linePosition
// add point at click position
var Line = viewer.entities.add({
polyline: {
width: 5,
}, Cesium.ScreenSpaceEventType.MOUSE_MOVE, );
This works fine as far as the functionality goes. I store the coordinates of the first click in a array, store the coordinates of the current mouse position (CallbackPoperty) in that array as well and use the array to draw a temporary line. Once I click again the actual line gets drawn
The problem is, that the temporary line only shows while I move the mouse. As soon as its still the line disappears and shows up again when moving the mouse.
I do understand why this is happening. My question is, if there is a workaround.
Thanks in advance
