DSM creation from 3D Scene
Cesium version: 1.131
I try to create a DSM (Digital Surface Model) as raster out of the existing 3D Scene in Cesium. The scene has 3D Tiles, Terrain, and GLTF objects in it and i would like to create a DSM for a ceratin extent out of it. The raster should have different resolution like 5x5m, 1x1m or 10x10m. The extent could be easily 1kmx1km. I started with scene.sampleHeightMostDetailed(), but for bigger extents it takes really long and that is why i am looking for a faster approach.
I tried so far:
Direct depth buffer sampling with world position reconstruction, which reconstructs world positions from the depth buffer and extracts heights.It works like that
  1. Setting up an orthographic camera positioned above the target area looking straight down
  2. Createe a post-process shader that:
    • Reads depth from Cesium’s depth buffer using czm_readDepth(czm_globeDepthTexture, ...)
    • Reconstructs world-space positions from depth using czm_windowToEyeCoordinates() + czm_inverseView
    • Extracts geodetic height from those world positions (ECEF coordinates)
    • Encodes the height values into RGB channels for readback
  3. Render the scene with the post-process stage applied to get the encoded height data
  4. Reads back pixels from the framebuffer using the WebGL context
  5. Decoding the RGB pixels back into height values and calculates statistics
Essentially, it’s leveraging Cesium’s depth buffer and built-in matrix uniforms (czm_inverseView, etc.) to convert rendered pixels into elevation data for the geographic extent.
here is a code snippet:
const worldPositionShader = `
      uniform sampler2D colorTexture;
      uniform float u_minHeight;
      uniform float u_heightRange;
      in vec2 v_textureCoordinates;
      void main() {
        // Read depth using Cesium's built-in function
        float depth = czm_readDepth(czm_globeDepthTexture, v_textureCoordinates);
        if (depth >= 0.9999) {
          // No geometry
          out_FragColor = vec4(1.0, 0.0, 1.0, 0.0);
          return;
        // Reconstruct window coordinates
        vec2 windowCoord = v_textureCoordinates * czm_viewport.zw + czm_viewport.xy;
        // Get raw depth for position reconstruction
        float rawDepth = texture(czm_globeDepthTexture, v_textureCoordinates).r;
        // Convert window coordinates to eye space
        vec4 eyePosition = czm_windowToEyeCoordinates(windowCoord, rawDepth);
        // Transform from eye space to world space
        vec4 worldPosition = czm_inverseView * eyePosition;
        worldPosition /= worldPosition.w;
        // Convert Cartesian world position to Cartographic (lon, lat, height)
        // We need the height above ellipsoid
        vec3 posECEF = worldPosition.xyz;
        // Approximate height calculation using ellipsoid radius
        // For WGS84: semi-major axis = 6378137.0, semi-minor = 6356752.3142
        float a = 6378137.0;
        float b = 6356752.3142;
        // Distance from Earth center
        float r = length(posECEF);
        // Approximate geodetic height (simplified, assumes roughly spherical)
        // For more accuracy, we'd need full geodetic conversion
        float lat = asin(posECEF.z / r);
        float N = a / sqrt(1.0 - (1.0 - (b*b)/(a*a)) * sin(lat) * sin(lat));
        float height = r - N;
        // Adjust for latitude (rough approximation)
        float cosLat = cos(lat);
        if (cosLat > 0.001) {
          height = length(posECEF.xy) / cosLat - N;
        // Normalize and encode height
        float heightNormalized = (height - u_minHeight) / u_heightRange;
        heightNormalized = clamp(heightNormalized, 0.0, 1.0);
        float encoded = heightNormalized * 16777215.0;
        float red = floor(encoded / 65536.0);
        float green = floor(mod(encoded, 65536.0) / 256.0);
        float blue = mod(encoded, 256.0);
        out_FragColor = vec4(red / 255.0, green / 255.0, blue / 255.0, 1.0);
    const { minHeightRange = -1000, maxHeightRange = 10000 } = config;
    const heightRange = maxHeightRange - minHeightRange;
    postProcessStage = new PostProcessStage({
      fragmentShader: worldPositionShader,
      uniforms: {
        // eslint-disable-next-line @typescript-eslint/naming-convention
        u_minHeight: minHeightRange,
        u_heightRange: heightRange,
    scene.postProcessStages.add(postProcessStage);
The second approach i tried is creating a DSM (Digital Surface Model) raster from the current Cesium scene by using an off-screen framebuffer with proper logarithmic depth decoding. It works like that:
  1. Saves the camera state and scene settings
  2. Enables depth features - Turns on depthTestAgainstTerrain and useDepthPicking so the depth buffer gets populated
  3. Positions camera above the target area looking straight down (keeps perspective frustum, not orthographic)
  4. Waits for terrain tiles to load at the new camera position, then renders several frames to ensure the depth buffer is populated
  5. Creates a post-process shader that:
    • Reads depth directly from gl_FragCoord.z
    • Uses czm_windowToEyeCoordinates() to convert window-space depth to eye-space position
    • Transforms to world space with czm_inverseView
    • Calculates ellipsoid height from the world position
    • Encodes the height into RGB channels
  6. Adds the shader as a post-process stage to the scene and renders
  7. Reads back the framebuffer pixels using the WebGL context
  8. Decodes RGB pixels back to height values and calculates statistics
  9. Restores the original camera and scene state
* Post-process shader that reconstructs world position from GL depth and extracts ellipsoid height.
* PostProcessStage doesn’t provide depth texture access by default.
* Instead, we use gl_FragCoord.z to read the depth value directly from the depth buffer.
* For perspective projection:
* 1. Read depth directly from gl_FragCoord (window-space depth)
* 2. Use czm_windowToEyeCoordinates to get eye-space position
* 3. Transform to world coordinates using czm_inverseView
* 4. Calculate the ellipsoid height from the world position
* => encode the height into RGB channels for readback (24-bit precision).
const depthToHeightShaderV2 = `
uniform vec3 u_radiiSquared;
  // Calculate height above ellipsoid from world position
  float getEllipsoidHeight(vec3 worldPos, vec3 radiiSquared) {
    // Normalize to ellipsoid surface
    vec3 oneOverRadiiSquared = 1.0 / radiiSquared;
    // Find the closest point on ellipsoid
    vec3 pos = worldPos;
    float beta = 1.0 / sqrt(
      pos.x * pos.x * oneOverRadiiSquared.x +
      pos.y * pos.y * oneOverRadiiSquared.y +
      pos.z * pos.z * oneOverRadiiSquared.z
    vec3 surfacePoint = pos * beta;
    float surfaceHeight = length(surfacePoint);
    float actualHeight = length(worldPos);
    return actualHeight - surfaceHeight;
  void main() {
    // WORKAROUND: Since PostProcessStage doesn't expose depth texture,
    // use the fragment's own depth value (gl_FragCoord.z)
    // This only works if the post-process stage writes to the same framebuffer
    float depth = gl_FragCoord.z;
    // Check for sky/no geometry
    if (depth >= 0.9999 || depth <= 0.0001) {
      out_FragColor = vec4(1.0, 0.0, 1.0, 0.0); // Magenta = no data
      return;
    // Get window coordinates from texture coordinates
    // Convert window position + depth to eye coordinates
    // czm_windowToEyeCoordinates expects the depth value from the depth buffer
    vec4 eyeCoord = czm_windowToEyeCoordinates(windowCoord, depth);
    vec4 worldCoord = czm_inverseView * eyeCoord;
    vec3 worldPos = worldCoord.xyz / worldCoord.w;
    // Calculate ellipsoid height
    float elevationMeters = getEllipsoidHeight(worldPos, u_radiiSquared);
    // Normalize and encode to RGB
    float heightNormalized = (elevationMeters - u_minHeight) / u_heightRange;
    // Encode to 24-bit RGB
    float r = floor(encoded / 65536.0);
    float g = floor(mod(encoded, 65536.0) / 256.0);
    float b = mod(encoded, 256.0);
    out_FragColor = vec4(r / 255.0, g / 255.0, b / 255.0, 1.0);
// Get ellipsoid radii squared for height calculation
const { ellipsoid } = scene.globe;
const { radii } = ellipsoid;
const radiiSquared = new Cartesian3(
  radii.x * radii.x,
  radii.y * radii.y,
  radii.z * radii.z,
// Wait for terrain tiles to load at the new camera position
// eslint-disable-next-line no-console
console.log('Waiting for terrain tiles to load...');
// Helper to wait for tiles
const waitForTiles = async (maxWaitMs: number): Promise<void> => {
  const startTime = Date.now();
  let continueLoop = true;
  while (continueLoop) {
    scene.render();
    const { tilesLoaded } = scene.globe;
    const tilesToRender =
      (scene.globe as any)._surface?._tilesToRender?.length ?? 0;
    if (tilesLoaded && tilesToRender > 0) {
      console.log(`Tiles loaded. Tiles to render: ${tilesToRender}`);
      continueLoop = false;
    } else if (Date.now() - startTime > maxWaitMs) {
      console.log('Timeout waiting for tiles, proceeding anyway...');
    } else {
      // eslint-disable-next-line no-await-in-loop
      await new Promise<void>((resolve) => {
        setTimeout(() => {
          resolve();
        }, 100);
await waitForTiles(3000);
// Render several more frames to ensure depth buffer is populated
console.log('Rendering frames to populate depth buffer...');
for (let i = 0; i < 5; i += 1) {
  scene.render();
    setTimeout(() => {
      resolve();
    }, 50);
// Debug: Check if globe depth texture exists
// eslint-disable-next-line @typescript-eslint/no-explicit-any, no-underscore-dangle
const frameState = (scene as any)._frameState;
console.log('Frame state useLogDepth:', frameState?.useLogDepth);
// Check multiple places where depth might be stored
const globeDepth = (scene as any)._globeDepth;
const view = (scene as any)._view;
// eslint-disable-next-line no-underscore-dangle
const viewGlobeDepth = view?._globeDepth;
console.log('Scene._globeDepth exists:', !!globeDepth);
console.log('Scene._view exists:', !!view);
console.log('View._globeDepth exists:', !!viewGlobeDepth);
if (viewGlobeDepth) {
  // eslint-disable-next-line no-console, no-underscore-dangle
  console.log('View globe depth framebuffer:', viewGlobeDepth._framebuffer);
  console.log('View globe depth texture:', viewGlobeDepth._colorTexture);
// Also check picking depth
const pickingDepth = (scene as any)._picking?.pickDepth;
console.log('Picking depth exists:', !!pickingDepth);
// Create post-process stage with updated uniforms
  fragmentShader: depthToHeightShaderV2,
  uniforms: {
    u_radiiSquared: radiiSquared,
// Add post-process stage
// Render with the post-process stage
scene.render();
// Wait a frame for async operations and render again
  setTimeout(() => {
    resolve();
  }, 100);
scene.render();
But for both approaches i am getting DSM statistics like this:
DSM created with statistics:
Min Height: -1000.00 m
Max Height: -1000.00 m
Center Height: -1000.00 m
Average Height: -1000.00 m
Valid Pixels: 1048576 / 1048576
So it does not work out. It is more or less R&D and just a prototype figuring out if that would be possible. Has anyone an idea if that would be kind of possible or is it just a stupid idea to create a DSM export like that not using sampleHeightMostDetailed()?
Many thanks in advance. Every comment is highly welcome :slight_smile:
BR Thomas
Hi @Thomas_Adolphi, what are you wanting to do with this digital surface model?
If you need to reconstruct the heights with the same accuracy and precision as the input data, you would probably be better off computing it offline, directly from the input. The depth buffer used in GPU rendering has limited precision.
Thanks for looking into this. The basic idea was to give users the possibility to directly export the DSM from scene into geotiff to be used in external software tools. At least for some kind of simulations, like wind or greeness visibility the DSM of a certain area is needed.I want to export the DSM in 5x5m raster resolution and export areas could be easily about 1x1km or more. But not more then 2.5x2.5km. But in the end we are talking about more then 40000 points to get the height of.
But maybe it is not doable in a reasonable time…
BR Thomas
