I’m trying to dynamically draw polygons as the user moves their mouse. However, whenever a new point is selected after the 2nd point, it seems to reset the heights of all previous points to 0, while keeping the height of the most recent point. I’m not editing the height of the points anywhere, so I’m not sure what could be causing this. I believe it might be something to do with the callback function, since the heights of points are not edited if the callback function is replaced with static data for the polygon positions.
Below I’ve included code that is compatible with sandcastle to help debugging. I’ve also added helper functions for logging the heights of all points in the array to the console and to fetch the maximum height of the points.
viewer.terrainProvider = Cesium.createWorldTerrain();
var polyShapePoints = ;
var mousePoint = null;
var polyShapeEntity = null;
function getMaxHeight(points) {
var maxHeight = Cesium.Cartographic.fromCartesian(points[0]).height;
points.forEach((point) => {
if (Cesium.Cartographic.fromCartesian(point).height > maxHeight) {
maxHeight = Cesium.Cartographic.fromCartesian(point).height;
return maxHeight;
function logHeights(points) {
console.log(Cesium.Cartographic.fromCartesian(point));
console.log("point height: " + Cesium.Cartographic.fromCartesian(point).height);
function addEnt() {
var maxHeight = getMaxHeight(polyShapePoints);
console.log("max height: " + maxHeight);
polyShapeEntity = viewer.entities.add({
polygon: {
hierarchy: new Cesium.CallbackProperty(function() {
return […polyShapePoints, mousePoint];
}, false),
material: Cesium.Color.WHITE,
height: maxHeight
new Cesium.ScreenSpaceEventHandler(viewer.canvas).setInputAction(function (event) {
var cartesianPosition = viewer.scene.pickPosition(event.position);
if (polyShapePoints.length === 0) {
polyShapePoints.push(cartesianPosition);
addEnt();
} else {
viewer.entities.remove(polyShapeEntity);
addEnt();
logHeights(polyShapePoints);
mousePoint = viewer.scene.pickPosition(event.endPosition);
I’m trying to dynamically draw a polygon as the user moves their mouse and left clicks to add permanent positions
Cesium Version: 1.52
OS: Ubuntu
Browser: Chrome
