I want to draw polygon dynamicly. The code below works fine when i add a static polygon primitive to the scene.
var geometry = new Cesium.PolygonGeometry({
polygonHierarchy : new Cesium.PolygonHierarchy(
Cesium.Cartesian3.fromDegreesArray([
-109.080842,45.002073,
-105.91517,45.002073,
-104.058488,44.996596,
-104.053011,43.002989,
-104.053011,41.003906,
-105.728954,40.998429,
-107.919731,41.003906,
-109.04798,40.998429,
-111.047063,40.998429,
-111.047063,42.000709,
-111.047063,44.476286,
-111.05254,45.002073])
var instance = new Cesium.GeometryInstance({
geometry:geometry,
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.WHITE.withAlpha(0.5))
viewer.scene.primitives.add(new Cesium.GroundPrimitive({
geometryInstances : instance,
appearance : new Cesium.PerInstanceColorAppearance()
But when I transplant it to the dynamic scene, it throws error:
viewer.scene.globe.depthTestAgainstTerrain = true;
var activeShapePoints = [];
var activeShape;
var floatingPoint;
function createPoint(worldPosition) {
var point = viewer.entities.add({
position: worldPosition,
point: {
color: Cesium.Color.WHITE,
pixelSize: 8,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND
return point;
function drawShape(positionData) {
polygonHierarchy : new Cesium.PolygonHierarchy(positionData)
geometry : geometry,
attributes : {
var shape = viewer.scene.primitives.add(new Cesium.GroundPrimitive({
return shape;
function terminateShape() {
activeShapePoints.pop();
if (activeShapePoints.length) {
drawShape(activeShapePoints);
viewer.entities.remove(floatingPoint);
viewer.entities.remove(activeShape);
floatingPoint = undefined;
activeShape = undefined;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
handler.setInputAction(function (event) {
var earthPosition = viewer.scene.pickPosition(event.position);
if (Cesium.defined(earthPosition)) {
if (activeShapePoints.length === 0) {
floatingPoint = createPoint(earthPosition);
activeShapePoints.push(earthPosition);
var dynamicPositions = new Cesium.CallbackProperty(function () {
return new Cesium.PolygonHierarchy(activeShapePoints);
}, false);
activeShape = drawShape(dynamicPositions);
if (Cesium.defined(floatingPoint)) {
var newPosition = viewer.scene.pickPosition(event.endPosition);
if (Cesium.defined(newPosition)) {
floatingPoint.position.setValue(newPosition);
activeShapePoints.push(newPosition);
terminateShape();
}, Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
I want to dynamicly drawing polygon with Primitive API by mouse click.
Cesium1.68, Windows 7, Chrome
