Hallo, I'm new to Cesium and have just downloaded the latest version.
I've implemented the hello world demo and it works fine. However I would like to have an elliptical worldmap simular to the top right image in this page:
(Don't know the name of this projection)
Is this possible?
Best regards - Ulrich
Hi there,
Cesium 2D mode only supports the Web Mercator Projection. If you would like to use another projection, I would suggest using a 2D solution alongside Cesium. If you just want to adjust the border to make it elliptical, you can do that with HTML and CSS.
Gabby
Hallo Gabby, thanks for this hint. In the meantime we found a way to work around this issue.
