I try to reproduce the example from here :
I copy/pasted the exact same code, but cannot get it to work. While the example works fine in my browsers, I only get the globe to work properly, but no lines are displayed.
I then tried to modify the viewer parameters, which are working properly (terrain provider displays mountains, disabling widgets works as well).
I triggered a few breakpoints to make sure that viewer.entities.add() was actually adding data in the entities array, and I can confirm that the array has new objects after each add().
I also tried to change the line's width and color but to no end.
To keep it simple, I'll focus on a single polyline.
The polyline is not shown, the camera stays at default position, but the entities array has not object before the add(), and one object after.
My page is structured like so:
<!DOCTYPE html>
<html>
<head>
<link rel='stylesheet' href='./source/libraries/Cesium/1.45/Widgets/widgets.css'>
</head>
<body>
<div id='cesiumContainer'></div>
<script type='text/javascript' src='./source/libraries/Cesium/1.45/Cesium.js'></script>
<script type='text/javascript' src='./source/view/3D.js'></script>
</body>
</html>
3D.js contains the following :
(function() {
var redLine = viewer.entities.add({
name : 'Red line on the surface',
polyline : {
positions : Cesium.Cartesian3.fromDegreesArray([-75, 35,
-125, 35]),
width : 5,
material : Cesium.Color.RED
I'm trying to display a polyline to represent a pedestrian pathway that needs to be in focus.
Cesium 1.45, Mac OS 10.13.3, Safari 11.0.3, Chrome 66.0.3359.181, Firefox 60.0.1.
