Is there a simple way to have the functionality of Camera.flyTo(…) but for an entity? I want an entity to interpolate to a new location, and the only way I can figure out how to do that is to use a SampledPositionProperty … however, that appears to have some hairy edge cases (like since I need to give it two samples to interpolate between, I need to give it a starting position … which I get with entity.position.getValue( now ) … however, after an interpolation completes, if I want to start a new one, the entity.position.getValue( now ) returns undefined because the time is now outside the bounds of the samples for that previous SampledPositionProperty.
Thanks for the reply, Hannah. I think that my original question was a little unclear … it’s not the camera that I want to move, it’s the entity itself. I would like to interpolate its position from one location to another over a period of time.
Yes, that example uses the SampledPositionProperty that I mentioned in my original post, which comes with all the hairy edge conditions I mentioned. It turned out that implementing my own interpolation from scratch was an easier solution than dealing with those edge conditions. :o(
It looks like there isn’t anything like flyTo for entities, which is a shame.
Oh gosh, sorry for not reading thoroughly ><
Yeah, I don’t think we have something like that that’s really easy to do. You would have to use a CallbackProperty for the position and write your own interpolation in the callback function.
Here’s an example of using an EllipsoidGeodesic to interpolate the pin’s position across the globe:
var viewer = new Cesium.Viewer(‘cesiumContainer’, {timeline : false, animation : false});
var start = Cesium.Cartographic.fromDegrees(-100, 39);
var end = Cesium.Cartographic.fromDegrees(-75, 20);
var geodesic = new Cesium.EllipsoidGeodesic(start, end);
var position = new Cesium.Cartographic();
var ellapsed = 0;
var time = 3;
var callback = function(){
position = geodesic.interpolateUsingFraction(ellapsed/time, position);
ellapsed += 1/60;
ellapsed = Math.min(ellapsed, 1);
return Cesium.Cartesian3.fromRadians(position.longitude, position.latitude);
var pinBuilder = new Cesium.PinBuilder();
var bluePin = viewer.entities.add({
position : new Cesium.CallbackProperty(callback, false),
billboard : {
image : pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 48).toDataURL(),
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
Sorry there’s not a better way to do this currently.
