I am using Resium (a ReactJS wrapper for CesiumJS) and I am facing what seems to be an issue with the way the entities collection is managed by the Viewer.
In a parent component I am updating a list of points of interest (POI) containing lon/lat coordinates and an id. I am passing this list of POIs as a prop to a child component wrapping a resium’s Viewer component.
In the child component, I am dynamically building a list of Entity component from the list of POIs. I have a useEffect
hook which calls cesium’s viewer flyTo
method to the first entity every time the list of POI changes.
Expected
The viewer should fly to the first created entity every time the POI prop changes.
Observed
Some time, the viewer does not fly to the first entity.
Investigations
While debugging the calls stack, it seems that at the moment the flyTo
method is being called in the useEffect
callback, the viewer’s DataSourceDisplay
instance does not contain the new Entities collection when the getBoundingSphere
method is being called on it. This result in a FAILED
state for the entity bounding sphere which makes updateZoomTarget
return early.
I have raised it on resium’s github issues and opened a SO thread about it.
I have deployed a simple demo for repro here
And the source are available here
