I want to zoom on the more then 1 entity Please suggest me and tall me how can i do it.
You can zoomTo or flyTo an array of entities using the Viewer functions.
viewer.zoomTo([entity1, entity2]);
See the Camera Controls section of the Visualizing Spatial Data tutorial for more details.
Neither zoomTo nor flyTo are working for me when I provide entities. I need to manually produce my own latlon array from the entities.
If for example I execute this from the JS console:
viewer.zoomTo(viewer.entities)
I just get:
Object { then: e(), resolve: r(), reject: n(), progress: s(), promise: Object, resolver: Object }
and no movement/change in the view. Doesn’t work if I provide any of my known entities either.
I am using v1.13.
That return value is expected because zoomTo returns a promise that let’s you know when the zoom is complete (or fails). If it’s generating an error orotherwise failing, you can get more information with the below code:
.then(function(result){
if(!result) {
console.log(‘Zoom was canceled or entities not in scene’);
.otherwise(
function(error) {
console.log(error);
Here’s a complete working example that zooms to 3 entities: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Box.html&label=Geometries
If you are still having problems, can you please post post a small complete example that shows your code, something we can reproduce using Sandcastle.
Thanks
There was a small typo in my code (extra
The working code is:
.then(function (result) {
if (!result) {
.otherwise(function (error) {
console.log(error);
I’ll try to produce a small example. Right now all my project is in:
http://davidrlowe.github.io/pic/
I want to zoom in to a PolylineCollection called lines this is what I get in the console when I type lines:
Object { modelMatrix: Object[16], _modelMatrix: Object[16], debugShowBoundingVolume: false, _opaqueRS: Object, _translucentRS: Object, _colorCommands: Array[1], _pickCommands: Array[1], _polylinesUpdated: false, _polylinesRemoved: false, _createVertexArray: false, 11 more… }
This is what I get when I type your code with lines as input:
viewer.zoomTo(lines)
if (!result) {
console.log('Zoom was canceled or entities not in scene');
console.log(error);
results in:
Object { then: e() }
No movement.
I see the confusion. PolylineCollection is not part of the Entity API, it’s part of the older Primitive API. I would suggest against using PolylineCollection and instead use the Entity API instead. Check out the full Visualizing Spatial Data tutorial for details
see this thread for my current situation: https://groups.google.com/forum/#!topic/cesium-dev/rRlnJ63Zo0U
Thanks Matthew you are angle
There is some way to do this but with 3d tiles.
zoom to several buildings that have the property show = true for example
thaks
For doing this with 3D Tiles, see the discussion here:
https://groups.google.com/d/msg/cesium-dev/Xsbvl3Q_WdQ/M_EZbLEbFQAJ
