Entity Polygon Alpha Flickering
I’m trying to add multiple entities to a datasource, each one containing a polygon with an alpha value set, however when a new entity is added the alpha values for all the other polygons in the collection appear to flicker or flash to 100% briefly before returning to their original values.
var dataSource = new Cesium.CustomDataSource(‘Polygons’);
var x = 0;
var y = 0;
setInterval(function(){
x += 5;
y += 2;
var area = [0 + y, 51 + x, 5 + y, 51 + x, 2.50 + y, 48 + x];
dataSource.entities.add({
show : true,
polygon : {
hierarchy :{
positions: Cesium.Cartesian3.fromDegreesArray(area)
material : Cesium.Color.RED.withAlpha(0.5)
}, 1000);
In the full code being used in our application I’m trying to fade the polygons out over time (as per the advice in https://groups.google.com/forum/#!newtopic/cesium-dev/cesium-dev/kbTxKXbRF44) - but it still seems to occur when using a solid colour too.
Also from what I can tell this doesn’t appear to be the case for other types in an entity, for example polylines or billboards.
Many Thanks,
Oliver
Hello Oliver,
Thanks for including the code sample! I was able to reproduce this on my machine. I submitted an issue to our Github: https://github.com/AnalyticalGraphicsInc/cesium/issues/3945
Hannah
This has been fixed and will be available in the Cesium 1.45 release available on May 1st.
Thanks!
Hannah
