I’ve been adding ellipsoid entities to represent noise monitor locations. However, most of the locations have been near an ocean or in areas with elevation near sea level. I recently looked at data around Denver, CO and noticed that the position of the ellipsoids appears to move/glide across the surface of the globe when I tilt the globe.
It’s hard to show very well in a picture, but I’ve added a couple of screenshots to try to better illustrate the issue. The first picture is looking straight down, and the ellipsoids are positioned where they should be. However as I start to tilt the globe away the ellipsoids appear to move across the surface of the globe toward the camera as seen in the second picture (all of the ellipsoids appear to move… I added a few arrows near ones that have easy visual references in the tiles around them).
I have not been able to replicate the issue in Sandcastle. I put the following example together, but as I stated it does not exhibit the problem. This makes me wonder if my globe/elevation settings are somehow coming into play. I could have just added one ellipsoid entity (and I did initially), but in order to eliminate as many variables as possible I tried replicating my code in the Sandcastle example as closely as I could. The ellipsoid radii and material along with the label text are updated via callback properties in my code. But when I eliminate the callback properties and simply set a value as in this example I still am getting the same position moving issue.
Any ideas as to why these ellipsoids would appear to move when I tilt the globe?
Rob
Sandcastle example:
var lstNMS = ;
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.71386, 39.91342, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.71449, 39.94071, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.69054, 39.97209, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.52659, 39.88391, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.52661, 39.86758, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.62164, 39.79782, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.66348, 39.75366, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.75777, 39.84132, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.75127, 39.93749, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.79585, 39.95961, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.83249, 39.97904, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.94630, 39.94179, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.93377, 39.92068, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.96673, 39.91066, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.93136, 39.90431, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.94985, 39.88058, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.94443, 39.86318, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.95437, 39.83997, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.91327, 39.83498, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.91656, 39.80739, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.83585, 39.75997, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.83780, 39.71838, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.80171, 39.71663, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.75819, 39.74609, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.63775, 39.92862, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.74136, 39.91173, 0));
lstNMS.push(Cesium.Cartesian3.fromDegrees(-104.80629, 39.99073, 0));
var lstEllipsoids = ;
for (var i=0; i<lstNMS.length; i++) {
var pos = lstNMS[i];
var newEllipsoid = viewer.entities.add({
position: pos,
show: false,
ellipsoid : {
radii : new Cesium.Cartesian3(500.0, 500.0, 1),
material : Cesium.Color.YELLOW
label: {
text: '67',
font: '100 72px sans-serif',
fillColor: Cesium.Color.BLACK,
outlineColor: Cesium.Color.BLACK,
outlineWidth: 1.0,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
scale: 0.2,
eyeOffset: new Cesium.Cartesian3(0.0, 0.0, -200.0)
lstEllipsoids.push(newEllipsoid);
for (var j=0; j<lstEllipsoids.length; j++) {
lstEllipsoids[j].show = true;
