I have a simple GLB file that contains a single animation and I would like to trigger that animation in cesiumjs. I used the code below to create the Entity and assign the model but nothing displays. There is a lot of old information out there showing different ways of accomplishing this but none seem targeted a similar version or approach.
I am using cesiumjs (and resium where applicable) to drive a small React app. The app shows a glob and nothing else except my GLB Entity.
Should I do this animation triggering with JS through an Entity and specify model (like below) or do I have to use ModelGraphics. Even better is there a code snippet or example I might take a look at that uses cesiumjs to load a glb file and turn on/off the embedded animation.
Thank you.
const position = Cesium.Cartesian3.fromDegrees(
-123.0744619,
44.0503706,
2000
let satellite = <Entity
key={"12"}
id={"13"}
name={"Some name"}
description={"Some description"}
position={position}
model={{
uri:"../public/junk-iss.glb",
minimumPixelSize: 256,
maximumScale: 20000
