Error in creating scene object
I am running the following code. when scene object is created using the canvas, following error occurs
Cesium.js:159461 Uncaught TypeError: canvas.getContext is not a function
at new Context (Cesium.js:159461)
at new Scene (Cesium.js:205696)
at cesium5.html:28
    var canvas = document.getElementById('cesiumContainer');
    var scene = new Cesium.Scene({
      canvas : canvas,
      contextOptions : {
        allowTextureFilterAnisotropic : false
    var primitives = scene.primitives;
    var globe = new Cesium.Globe(Cesium.Ellipsoid.WGS84);
    scene.globe=globe;
I need to display my terrain data using geoserverterrainprovider
My cesium version is 1.38
Hi there,
Don’t create the scene directly, try creating the the viewer with Cesium.Viewer. You can then access the scene with Viewer.scene. Check out the Terrain Sandcastle Example for an example of creating the Viewer and adding terrain.
Gabby
