how use Cesium3DTileset
I create MVC Demo, add build Folder of Cesium-1.50 to script Folder and want to create View such as below,but when I Run it got this Error:
Cesium.Cesium3DTileset is not a constructor
    at window.onload
       window.onload = function () {
            var viewer = createViewer("viewer", "@Url.Content("~/Scripts")");
            var scene = viewer.scene;
            Cesium.Cartesian3.fromDegrees(53.9868, 26.5325, 0.0);
            var tileset =
                scene.primitives.add(new Cesium.Cesium3DTileset({
                    url: ‘https://d35ei6ur3bjvr1.cloudfront.net/berlin/small_untextured’
            scene.terrainProvider = new Cesium.CesiumTerrainProvider({
                url: ‘https://d35ei6ur3bjvr1.cloudfront.net/berlin/86bd7c93-de44-455d-9efa-a41238172216’
Cesium-1.50,Google Chrome latest version
How are you loading in Cesium? What does the “createViewer” function look like? Make sure you’re correctly including everything as described here:
