From version b-30
I’m getting the following error when trying to load one of vwf’s cesium demos. I’m sure I just don’t have something set up correctly, since a lot has changed since we last had this demo working( I think b24 or even earlier was the last time the demo was working ). I checked the stack and the code was in the middle of loading the Moon object. I was just curious if anyone had any insight into what I might check to see what the problem is.
TIA,
Scott
Uncaught DeveloperError: material with type ‘[object Object]’ does not exist.
Error
at new DeveloperError (http://localhost:3000/agi/test/polygon/47dff4421c291624/vwf/model/cesium/Core/DeveloperError.js:43:19 )
at Function.Material.fromType ……9) localhost:3000/agi/test/polygon/47dff4421c291624/vwf/model/cesium/Scene/Material.js:347
