ES6 module import throws error after v1.66
Hey all! I am experiencing a strange behavior when importing Cesium as ES6 module in my Angular application. Before version 1.67, the following snippet works correctly:
import { Viewer } from 'cesium';
In version 1.67 I get the following errors:
In version 1.68 I cannot import the module at all:
I believe you need to set up your project to ignore these libraries as described here: https://github.com/CesiumGS/cesium/issues/8673#issuecomment-604045983
Can you try that and let me know if it works?
@omar yes it worked for version 1.67 ! Thanks very much :pray:. I should watch for Angular related issues in the Github repo from now on :smiley:
The problem in version 1.68 still persists. I will try to reproduce it with the cesium-webpack example and let you know.
@omar it works ok with the webpack example and I found out that it works also with the Angular CLI. The errors that are shown come from the typescript compiler b/c it cannot find the required types. Overall, it works as expected. Furthermore, I installed @types/cesium package and the compiler errors are gone. :pray: for your help.
