Can't import widgets.css in ES6 style
I’m working on cesium-webpack-app and want to use modules in ES6 style. I know how to import Cesium.js, but I can’t import stylesheet, ‘widget.css’.
I found this code below in QuickStart
import "cesium/Build/Cesium/Widgets/widgets.css";
But it doesn’t work. The error message is
Module not found: Error: Package path ./Build/Cesium/Widgets/widgets.css is not exported from package C:\***\cesium-webpack-app\node_modules\cesium (see exports field in C:\***\cesium-webpack-app\node_modules\cesium\package.json)
So, I changed ‘exports’ in node_modules/cesium/package.json like this.
"exports": {
        "./package.json": "./package.json",
        "./Build/Cesium/Widgets/widgets.css": "./Build/Cesium/Widgets/widgets.css", <=added
            "require": "./index.cjs",
            "import": "./Source/Cesium.js"
and this work to me.
Is it right solution?
Try this.
Thanks! I’ll try it.
