Hi! I'm trying to change the z coordinate for a set of GeoJSON points. So far, I've imported a GeoJSON object into a GeoJsonDataSource, and the points themselves have one z coordinate, with the other as a separate attribute. I can find many instances where we can extrude polygons off a specific attribute, however I can't find where to extrude _points_.
var ds = new Cesium.GeoJsonDataSource.load(geojson,{}).then(function(ds){
viewer.dataSources.add(ds);
viewer.zoomTo(ds);
...................Event listener to trigger this portion of code.............
var entities = ds.entities.values;
for (var i=0;i<entities.length;i++){
var entity = entities[i];
*I WANT TO CHANGE ENTITY'S Z COORDINATE HERE*
Looking to change/extrude z coordinate from different altitude measurements (eg lidar vs barometric, etc). Forums say a "entity.polygon.heightExtrusion"... however there is no such thing as "entity.point.xxxxx".
