Hi!
I’m a collegue of @VI-JH with more focus on the C++ side. I could fix it for us and wanted to share my solution here.
My first idea was to do a custom Unreal Engine 5.4 build from Epic’s GitHub repository and fix the dependencies of nDisplay’s MCPDI library to a rather old version of tinyxml2. I guess this would be the most beatiful but also very time consuming solution.
Thats why I decided to go a rather simple way, which might not work, but fortunately with a little bit luck it did work for us as a dirty fix
Short Explanation:
I downloaded tinyxml2 (tag: 9.0.0) and made a small change to the code. I simply added the old required constructor of XMLPrinter with two parameters and was hoping the ABI is still correct. Here is my diff:
diff --git a/tinyxml2.cpp b/tinyxml2.cpp
index 31925d9..c6396de 100755
--- a/tinyxml2.cpp
+++ b/tinyxml2.cpp
@@ -2571,6 +2571,9 @@ XMLPrinter::XMLPrinter( FILE* file, bool compact, int depth ) :
_buffer.Push( 0 );
+XMLPrinter::XMLPrinter( FILE* file, bool compact )
+: XMLPrinter( file, compact, 0 )
void XMLPrinter::Print( const char* format, ... )
diff --git a/tinyxml2.h b/tinyxml2.h
index 452ae95..10f459d 100755
--- a/tinyxml2.h
+++ b/tinyxml2.h
@@ -2243,7 +2243,8 @@ public:
If 'compact' is set to true, then output is created
with only required whitespace and newlines.
- XMLPrinter( FILE* file=0, bool compact = false, int depth = 0 );
+ XMLPrinter( FILE* file, bool compact, int depth );
+ XMLPrinter( FILE* file=0, bool compact = false );
virtual ~XMLPrinter() {}
/** If streaming, write the BOM and declaration. */
Note that I also had to change the existing constructor to not have default parameter values.
Thats all I changed. Compiled it and copied (overwrite) the used tinyxml.lib files from nDisplay AND Cesium.
nDisplay’s tinyxml2.lib: C:\Program Files\Epic Games\UE_5.4\Engine\Plugins\Runtime\nDisplay\Source\ThirdParty\MPCDI\Lib
Cesium’s tinyxml2.lib: C:\Program Files\Epic Games\UE_5.4\Engine\Plugins\Marketplace\CesiumForUnreal_5.4\Source\ThirdParty\lib\Windows-AMD64-Release
How I built tinyxml2 on Windows
git clone https://github.com/leethomason/tinyxml2.git
git checkout 9.0.0
- Open
vs/tinyxml2.sln with Visual Studio 2022
- In the Solution Explorer
- Expand tinyxml2 → Source Files and right click on
xmltext.cpp → Remove
- Right click on project tinyxml2 → Properties
- Navigate to General and set “Configuration Type” to “Static Library (.lib)”
- Click OK
- Apply above mentioned changes to source.
- Right click on project tinyxml2 → Build (make sure to select “Release” built in toolbar before starting)
Now you should find your tinyxml2.lib in $SRC/vs/x64/Release or folder.
Compiler Version: I used v143 (14.38.33130); Location: C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.38.33130
Thats It.
In case you want to give it a quick try, I uploaded my tinyxml2.lib to my drive: https://drive.google.com/file/d/1rKMqOYUIdc_Rz69MzQ0bFDfnskcGV05B/view?usp=sharing
Best
Manuel
PS: I’m aware that there is no gurantee that this will work forever or is considered “safe”, but it works for now.
Updated (13.05.25): I wrote Unreal Version 5.5 but we are currently bound to 5.4.
