Fix blinking entities
Hey, everybody. I create an entity in which I place PlaneGraphics. Then I create an ImageMetarialProperty and pass the path to my png or svg image. But if the entity is single, it blinks when I zoom or move the camera. When there are many objects everything is fine. Is there any way to fix this? I attach the code and video!
cesium.viewer.entities.add({
  name: "Red plane with black outline",
  position: new Cesium.Cartesian3.fromDegrees(-107.0, 40.0, 300000.0),
  plane: {
    plane: new Cesium.Plane(Cesium.Cartesian3.UNIT_Z, 0.0),
    material: new Cesium.ImageMaterialProperty({
      image: right,
      transparent: true,
      // color: new Cesium.Color(1.0, 1.0, 1.0, 0.9)
    dimensions: new Cesium.Cartesian2(1560000.0, 1561000.0)
cesium.viewer.scene.preRender.addEventListener(function () {
  let cameraHeight = cesium.viewer.scene.camera.positionCartographic.height;
  var newSize = 30000.0 * (cameraHeight / 2000000);
    newSize = Math.max(newSize, 100.0);
    let test = new Cesium.Cartesian2(newSize, newSize);
    let minHeight = 1000000;
    let maxHeight = 20000000;
  cesium.viewer.entities.values.forEach((item) => {
    console.log(item._plane._dimensions)
    if (cameraHeight > minHeight && cameraHeight < maxHeight) {
      item._plane._dimensions.setValue(test);
      cesium.scene.requestRender()
    if (cameraHeight  > 1000000) {
      item.show = true;
    }else {
      console.log(123123123)
      item.show = false
Video: https://www.veed.io/view/ee4f3a02-5ea3-469b-b2c7-7ca97be7dbdb?panel=share
It looks this happens because your entities are rendered asynchronously in the webworker. If you want the entity to render synchronously, you can use a CallbackProperty for the dimensions property of your plane geometry.
I’m not sure I fully understand your code, but please let me know if the following Sandcastle is what you’re looking for.
link to Sandcastle
Congratulations! Thanks, dude!
There is a problem, when there are a lot of objects, FPS drops… What should I do?
