Whenever I add a rectangle image fabric to the globe I have a white background while the image loads. Is there a way to prevent this? If the image is small enough in file size it loads instantly and you do not see it, but if the image is large enough it will display the white layer then overlay the image over it.
Yes, this is an existing issue. I don’t know of a workaround at this point.
